#118286 - 28/09/2002 14:59 floating-ground amplifiers
spopovic
Loc: CROATIA
Can some one tell what are these F-G Amps.
I' m buying one Amp for may EMPEG MARK1 player, and I don't know wich one.
Alpine MRV-F340
or Pioneer GM-X924
EMPEG Mk1 00158
#118287 - 29/09/2002 21:08 Re: floating-ground amplifiers [Re: spopovic]
genixia
I suspect that floating ground amps don't have their case or signal grounds connected to power ground. This would be useful when putting one in a strange-ass car that has it's body connected to the positive battery terminal.
#118288 - 02/10/2002 04:38 Re: floating-ground amplifiers [Re: genixia]
All (decent) in-car amps have floating ground inputs - anything from a name brand, definitely.
#118289 - 02/10/2002 09:36 Re: floating-ground amplifiers [Re: altman]
spopovic
Loc: CROATIA
Thank you..I'll take Alpine AMP.
EMPEG Mk1 00158
#118290 - 04/10/2002 09:32 Re: floating-ground amplifiers [Re: spopovic]
If you're installing a Mk.1 then the first thing you'll need to do is short those floating grounds to ground using the cables supplied!
#118291 - 04/10/2002 09:33 Re: floating-ground amplifiers [Re: rob]
I thought it was the opposite. I thought that the cables were supposed to make non-floating-ground amplifiers work properly with the Mk1.
Have I had it wrong all along?
#118292 - 04/10/2002 09:37 Re: floating-ground amplifiers [Re: tfabris]
The cables simply tie the RCA plug grounds to chassis ground - i.e. they defeat the floating input of most amplifiers. This is because the Mk.1 has floating outputs - you can't float BOTH ends of the connection (at least, not usually, but since this is a black art it has been known to happen).
#118293 - 04/10/2002 12:13 Re: floating-ground amplifiers [Re: rob]
I guess I was misunderstanding all along. So how should this FAQ entry be re-worded in order to be accurate?
#118294 - 04/10/2002 17:09 Re: floating-ground amplifiers [Re: tfabris]
Umm.. I guess you could delete it and start over!
The mechanics of the process are correct, just the reasoning is wrong. Just delete the reasoning - I'm sure most of the 350 Mk.1 owners have worked it out by now anyway.
#118295 - 04/10/2002 22:42 Re: floating-ground amplifiers [Re: rob]
Good idea. Done.
