#123014 - 24/10/2002 17:35 Logoedit 1.7
Available at riocar.org and at my home page. I'm going to skip making a headline on riocar.org for this release.
From the readme.txt:
    Added a feature to grab screen shots of the current screen
    from the player using FTP.
    Also added a feature (on the VIEW menu) to save the
    preview images as bitmaps. This option is only available
    when the preview window is actually up on the screen, it is
    grayed out at all other times. It will save both images as
    two separate files, the first being the name you choose
    in the Export dialog box, the second being that same name
    plus "_2" at the end. This is useful if you want to have
    nice-looking screen shots of the empeg screen. I don't have
    any code to save as GIF/JPG/PNG yet, only BMP, sorry. If
    anyone's got links to any license-free "VB code only"
    solutions for saving any of those file formats, please let
    me know.
#123015 - 24/10/2002 22:44 Re: Logoedit 1.7 [Re: tfabris]
ricin
Loc: US: CA
I'd recommend the FreeImage Library. It isn't "VB Code Only," but it is free. You'll get JPG/PNG. No GIF, because of UNISYS. PNG is better anyway.
Yes, it's been discontinued, but the latest version is still available. For now...
There's also code to use the Intel JPEG library.
Edited by ricin (24/10/2002 22:50)
Donato
MkII/080000565
MkIIa/010101253
ricin.us
#123016 - 25/10/2002 04:48 Re: Logoedit 1.7 [Re: tfabris]
DarkStorm
Loc: Pompano Beach, Florida
Hey, Tony. Is there anyway for me to use the AnnaVU and TuxMuch functions on my Mark I.
Oh Please don't say I have to have networking and need a Mark II.
Steve DarkStorm Designs
#123017 - 25/10/2002 07:44 Re: Logoedit 1.7 [Re: DarkStorm]
mtempsch
IIRC (been a while since I played with them) they're now files, and you should be able to
send them up through the serial connection (rz/sz, see the FAQ)
#123018 - 25/10/2002 10:04 Re: Logoedit 1.7 [Re: tfabris]
prolux
Loc: Manchester, UK
Hello Tony,
Great work for updating the functionality of Logo Editor - Just have to add capability to change the Image Pan image now.
I've had a problem with the grab boot logos from player (FTP) feature - It doesn't work and says 'Fatal error, attemped to load a non-empeg file" - Grabbing the Annu Vu and Tux Much images works fine though. Have only tried it on one player as only have one Hi-Jack enabled here. If no one else is having this problem then it's probably just something odd about my player.
Thought I would mention it anyway though,
Toby.
#123019 - 25/10/2002 10:20 Re: Logoedit 1.7 [Re: DarkStorm]
As mtempsch said, you need to use the serial cable. And you need to "prep" the files with EmRawerter before sending them. LogoEdit can't help you in this particular case, so click here for links to EmRawerter and instructions.
#123020 - 25/10/2002 10:23 Re: Logoedit 1.7 [Re: prolux]
Yup, that's on my to-do list. May take a while, though.
I can imagine only two situations where this would happen:
- Old version of Hijack that doesn't support the empeg_bootlogos FTP file.
- Player never had any custom boot logos installed to begin with, so the "empg" text does not exist as the first four bytes of the file it grabbed.
Is it either of those things?
#123021 - 06/11/2002 23:59 Re: Logoedit 1.7 [Re: tfabris]
mrfixit
Hey Tony, the vu and tux editing works great any news on the image pan editing feature
Ben
hijacked
#123022 - 07/11/2002 03:41 Re: Logoedit 1.7 [Re: mrfixit]
Someday.
#123023 - 07/11/2002 08:22 Re: Logoedit 1.7 [Re: tfabris]
mrfixit
Ok I will be waiting
Ben
hijacked
#123024 - 23/07/2007 01:51 Re: Logoedit 1.7 [Re: tfabris]
I'm a little confused about logos. There seems to be three different ones. A boot logo, and two others, home & car, that will display after the boot logo depending on if the player is starts in the car or at home. Have I got that right?
Also, I too, saw the error above, when I tried to save the stock boot logo before I started messing with uploads. Is it trying to get this file? /empeg/lib/visuals/empeg_logo.raw
#123025 - 23/07/2007 15:56 Re: Logoedit 1.7 [Re: gbeer]
Yes. In version 2.0 software, that boot logo is animated, so it's an animation file instead of a logo file, and you can edit that with Jemplode (if Hijack is installed). The home/car thing is the non-animated picture that appears after the animation is done playing.
No, it is trying to retrieve a sequence of bytes from a specific address in the player's flash RAM. Not a file.
If I recall correctly, I believe Mark has abstracted the logos and animations into something that can be accessed through Hijack FTP as if it were a file. But it's not really a file, it's just a symlink that appears in the filesystem that causes Hijack to access a certain section of flash RAM. And anyway, the file you listed above is not that link. I think it's something in /proc if I recall correctly.
