#125380 - 09/11/2002 13:09 No hard disk found contact support (another one)
furtive
Ggrrr.. Having repeated problems with my empeg (RioCar) not recognising the hard drives. Sometimes it works, sometimes it doesn't. I've had the thing apart and made sure that the cables are all secure, and they seem to be, and I can't see and sign of cracks in the solder holding the connector onto the mainboard.
Also, today whilst it was working, the sound kept breaking up - as if it was having trouble reading the data from the disk, although I don't know how this could be as it's obviously not like a CD that can get fingerprints all over it and skip.
Below is the boot sequence as copied from Hyperterminal. Anyone got any suggestions? Thanks.
empeg-car bootstrap v1.02 20001106 ([email protected])
e000 v1.04
Copying kernel...
Calling linux kernel...
Uncompressing Linux................................... done, booting the kernel.
Linux version 2.2.14-rmk5-np17-empeg51-hijack-v289 ([email protected]) (gcc ve
rsion 2.95.3 20010315 (release)) #2 Tue Jul 30 12:47:31 EDT 2002
Processor: Intel StrongARM-11
empeg-car player (hardware revision 9, serial number 10101920)
Command line: mem=16m
Memory: 15076k/16M available (928k code, 20k reserved, 356k data, 4k init)
Linux NET4.0 for Linux 2.2
Based upon Swansea Universit
IP Protocols: ICMP, UDP, TCP
Starting kswapd v 1.5
Signature is 636f6972 'rioc'
Scheduling custom logo.
empeg display initialised.
empeg dsp audio initialised
empeg dsp mixer initialised
empeg dsp initialised
empeg state support initialised 0089/88c1 (save to d0005280).
empeg RDS driver initialised
empeg single channel IDE
Probing primary interface...
smc chip id/revision 0x3349
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:22:07:8
0
empeg-pump v0.03 (19980601)
Press Ctrl-A to enter pump...Kernel panic: VFS: Unable to mount root fs on 03:0
Rio Karma - now on ebay...
#125381 - 09/11/2002 15:31 Re: No hard disk found contact support (another one) [Re: furtive]
Greetings!
There was a defective batch of drive cables that were shipped. It is likely that you have one of them. You should contact support for a replacement. As far as I know, there is no way to tell that you have a cable from the bad batch by eye.
#125382 - 09/11/2002 15:50 Re: No hard disk found contact support (another one) [Re: furtive]
eliceo
This sounds like what i was getting. Intermittent hard drive not found errors, the player would sometimes stutter . I replaced the cable which helped for some time, then finally it turned out to be a dry solder joint. Sending the player in for service fixed my problems.
#125383 - 09/11/2002 16:03 Re: No hard disk found contact support (another one) [Re: furtive]
Furtive, please check all of the possible problems listed here.
#125384 - 09/11/2002 16:43 Re: No hard disk found contact support (another one) [Re: tfabris]
furtive
I *did* used to have a defective cable when I first got my empeg, but that was replaced and it has worked fine ever since. I think a dry joint may be the cause of the problem. I have emailed support, and as I only live a stones throw from Cambridge, hopfully I can personallly drop my player off for them to have a look at.
Tony - yes, I have read, and re-read the FAQ to try and diagnose my problem. Thanks for reminding everyone about it though
#125385 - 09/11/2002 23:30 Re: No hard disk found contact support (another one) [Re: furtive]
matthew_k
I hate to point out the obvious, but perhaps the actual hard drive is going bad? Perhaps you should try with one drive then the other?
#125386 - 10/11/2002 03:44 Re: No hard disk found contact support (another one) [Re: matthew_k]
furtive
Is there any way to test the drives? Will both drive have the required boot information on it or will I have to reformat them one at a time, and therefore loose all my playlists, etc?
#125387 - 11/11/2002 12:01 Re: No hard disk found contact support (another one) [Re: furtive]
furtive
bump...
#125388 - 11/11/2002 12:24 Re: No hard disk found contact support (another one) [Re: furtive]
Hm? Oh, sorry. I was asleep.
Is the hard drive stress test non-destructive? I think it is, but I am not 100% certain... If it is non-destructive, you can run /bin/hdstress to give your drives a workout.
#125389 - 16/11/2002 06:07 Re: No hard disk found contact support (another one) [Re: furtive]
furtive
Right, I've been trying to diagnose this.
With both drives connected, It only gets as far as the sick penguin screen
With just one drive connected it *sometimes* boots ok, but sometimes still fails
So, I'm guessing either a dry joint where the drive connector is on the main board (I *think* I see a crack on one of the joints, but maybe not) or a duff cable, or something else...
I'm going to try and drop it off to David some time in the week...
I'll just have to sing in the car for now
#125390 - 20/11/2002 10:24 Re: No hard disk found contact support (another one) [Re: furtive]
furtive
Huge huge thanks to David Moss at empeg for fixing my player today. Top class customer service.
Apologies to Hugo for parking in your space!
