Ggrrr.. Having repeated problems with my empeg (RioCar) not recognising the hard drives. Sometimes it works, sometimes it doesn't. I've had the thing apart and made sure that the cables are all secure, and they seem to be, and I can't see and sign of cracks in the solder holding the connector onto the mainboard.
Also, today whilst it was working, the sound kept breaking up - as if it was having trouble reading the data from the disk, although I don't know how this could be as it's obviously not like a CD that can get fingerprints all over it and skip.
Below is the boot sequence as copied from Hyperterminal. Anyone got any suggestions? Thanks.
empeg-car bootstrap v1.02 20001106 (
[email protected])
e000 v1.04
Copying kernel...
Calling linux kernel...
Uncompressing Linux................................... done, booting the kernel.
Linux version 2.2.14-rmk5-np17-empeg51-hijack-v289 (
[email protected]) (gcc ve
rsion 2.95.3 20010315 (release)) #2 Tue Jul 30 12:47:31 EDT 2002
Processor: Intel StrongARM-11
empeg-car player (hardware revision 9, serial number 10101920)
Command line: mem=16m
Memory: 15076k/16M available (928k code, 20k reserved, 356k data, 4k init)
Linux NET4.0 for Linux 2.2
Based upon Swansea Universit
IP Protocols: ICMP, UDP, TCP
Starting kswapd v 1.5
Signature is 636f6972 'rioc'
Scheduling custom logo.
empeg display initialised.
empeg dsp audio initialised
empeg dsp mixer initialised
empeg dsp initialised
empeg state support initialised 0089/88c1 (save to d0005280).
empeg RDS driver initialised
empeg single channel IDE
Probing primary interface...
smc chip id/revision 0x3349
smc9194.c:v0.12 03/06/96 by Erik Stahlman (
[email protected])
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:22:07:8
0
empeg-pump v0.03 (19980601)
Press Ctrl-A to enter pump...Kernel panic: VFS: Unable to mount root fs on 03:0
