Tony,
Yes, I saw that in the FAQ as well as the, "How do I edit the 'config.ini' file on the player?" Neither seemed to pertain to my problem however. I have never set or added any favorite visuals nor have I used anything but emplode to edit the config.ini (and that was 6 months ago). Also, I am able to open the editor in Emplode.
I cannot edit the file through Emplode in the new version 2.0 final. I did not try it in the time I ran 2.0b13 though.
Also, my "winblows" XP reg setting does say the following under "settings" - allow_edit_config - value of 1
Opening the file in the editor in Emplode will allow me to delete characters but not add any characters. But when I select OK it askes me if "Are you sure that you want to write this text into the configuration file on your player? since i have not visually edited anything I have always said "no"
_____________
Sean in NC
130gb MK2a w/ 32mb ram
80gb MK2a empeg spare
