#153615 - 07/04/2003 02:54 Need some help with webmail
StigOE
I'm trying to get a webmail up and running, but my perl and Linux path skills aren't exactly top of the notch....
I have installed Nikosoft webmail (since it doesn't need an IMAP-server) and have set up Aliases and ScriptAlias in httpd.conf. Btw, is it possible to only have one ScriptAlias, but several Aliases?
The relevant parts in httpd.conf looks like this:
Alias /nswm "/opt/nswm/html"
<Directory "/opt/nswm/html">
Options Indexes MultiViews
AllowOverride None
Order allow,deny
Allow from all
</Directory>
Alias /nswmtemp "/tmp/nswm"
<Directory "/tmp/nswm">
AllowOverride None
Order allow,deny
Allow from all
</Directory>
ScriptAlias /cgi-bin/ "/opt/nswm/cgi-bin/"
<Directory "/opt/nswm/cgi-bin">
AllowOverride None
Options None
Order allow,deny
Allow from all
</Directory>
When I try to access the page, I get this error:
Can't locate configwm.pm in @INC (@INC contains: /usr/local/ActivePerl-5.8/lib/5.8.0/i686-linux-thread-multi /usr/local/ActivePerl-5.8/lib/5.8.0 /usr/local/ActivePerl-5.8/lib/site_perl/5.8.0/i686-linux-thread-multi /usr/local/ActivePerl-5.8/lib/site_perl/5.8.0 /usr/local/ActivePerl-5.8/lib/site_perl . /opt/nswm/cgi-bin/) at common.pm line 12.
BEGIN failed--compilation aborted at common.pm line 12.
Compilation failed in require at /opt/nswm/cgi-bin/login.pl line 12.
BEGIN failed--compilation aborted at /opt/nswm/cgi-bin/login.pl line 12.
Anyone have any suggestions how I can get this thing to work?
Stig
#153616 - 07/04/2003 06:22 Re: Need some help with webmail [Re: StigOE]
robricc
You don't need an IMAP server to get great webmail (Nikosoft Webmail doesn't look great). Neomail and Acmemail come to mind.
Sorry if I can't answer your question, but I have installed Neomail on a fair amount of servers and it worked everytime.
#153617 - 07/04/2003 07:29 Re: Need some help with webmail [Re: robricc]
I use Open Webmail which says it's based on Neomail, and I like it a lot. I didn't set it up though, my web host did.
#153618 - 07/04/2003 08:59 Re: Need some help with webmail [Re: Dignan]
leftyfb
Loc: Lowell, MA
I also use OpenWebmail and love it. I installed it so if you decide to use it and need help, drop me a line.
Mk2a 30GB Blue. Serial 030102999
#153619 - 08/04/2003 04:38 Re: Need some help with webmail [Re: leftyfb]
StigOE
Thanks for the offer, but I have after lots of trial and error managed to get Nikosoft Webmail up and running...
I tried OpenWebmail, but It didn\t work for me. Looks like it accesses the mailboxes directly instead of through the POP-server and uses /etc/shadow for users and my mailserver uses neither...
Stig
