#158681 - 02/05/2003 21:42 A question about JAnimEdit..
Banacek
Ok, so I'm trying to create my own animated boot logo, and I'm using JAnimEdit (as you could probably tell) and I'm having a little problem. No matter what I do, the Sequence List is always blank. Now if I add frames and hit play it shows the logo being animated, but it's hard to figure out when I can't see what I'm doing. Thanks..
#158682 - 02/05/2003 22:21 Re: A question about JAnimEdit.. [Re: Banacek]
So you're saying that you can draw frames in the left hand pane, then add those frames to the animation in the right hand pane, but one of those two parts of the screen is blank?
I assume from your description that it's the sequence window on the right hand side of the screen that's blank?
I suspect a problem with the version of the Java Run Time Engine being used. Did you install the Sun one or are you just using Microsoft's? Or perhaps you're running an old version of Jemplode? What are the versions of each?
Java: Write once, debug everywhere.
#158683 - 02/05/2003 23:12 Re: A question about JAnimEdit.. [Re: tfabris]
Banacek
Yeah, it's the right window which is blank. You know, it was a while ago, so I don't know which Java Runtime engine i got. So I went to Sun's website and downloaded their's and, that seemed to do the trick! Thanks again!
#158684 - 02/05/2003 23:14 Re: A question about JAnimEdit.. [Re: Banacek]
Ah, another satisfied customer. That'll be 20 dollars, please.
#158685 - 03/05/2003 08:41 Re: A question about JAnimEdit.. [Re: tfabris]
Banacek
The check's in the mail
#158686 - 04/05/2003 06:46 Re: A question about JAnimEdit.. [Re: tfabris]
mschrag
Loc: Richmond, VA
Every Alternative: Rewrite everywhere, debug everywhere.
#158687 - 04/05/2003 12:15 Re: A question about JAnimEdit.. [Re: mschrag]
Touche'.
