Hi there!
Here is a list of commands which can control the empeg via the serial port.
http://www.differentpla.net/~roger/empeg/car/serial.html
Can these controls be modified/translated with the [ir_translate] configuration ?
If yes - how to do it ?
I want to interface the sony remote control stick to the empeg make 1 - i know there is a solution for this, but it's not wornikng with v2, FF/REV does not work, and there is no way to access the menu. i want to have access to the menu via the control stick but the problem with the menu command is - the stick has to know if its in menu because the commands are other. or there is a way to simulate the fornt button presses via serial.
