#219470 - 23/06/2004 23:21 Making old programs play nice
I'm trying to install my old favorite composing software that I used over 6 years ago. I know it's a long shot, but I'd like to get it to play nice with 2K. It installed fine, and the MIDI test went smoothly, but I get the following error when I try to run the program:
Encore32.exe - Entry Point Not Found
The procedure entry point SMapLS_IP_EBP_12 could not be located in the dynamic link library KERNEL32.dll.
Any possibilities?
*edit*
If it helps, I can provide a link for downloading the product. I was still undecided as to how kosher it would be to just include it in this post, but then I discovered that the company that made the program isn't out of business like I thought. So PM me
Edited by DiGNAN17 (23/06/2004 23:31)
#219471 - 24/06/2004 01:45 Re: Making old programs play nice [Re: Dignan]
Try running it in Windows 95 compatibility mode. Does W2K have settings for that? In XP, it's available from the program's properties.
#219472 - 24/06/2004 03:25 Re: Making old programs play nice [Re: Dignan]
#219473 - 24/06/2004 11:54 Re: Making old programs play nice [Re: Roger]
Thanks for the link, though I'm not quite sure how to read it.
I thought about that compatability mode thing, but I can't seem to find it. I thought I tried using it for another program, but I don't know how. It should be in the properties for the executable, right? I don't see it in there.
#219474 - 24/06/2004 14:02 Re: Making old programs play nice [Re: Dignan]
Unfortunately, I don't think the Win95 compatibility mode exists in Win2K, it mght be an XP-only feature.
#219475 - 24/06/2004 20:40 Re: Making old programs play nice [Re: tfabris]
Correct.
But there is something similar in Win2K. You can choose the option to "Run in separate memory space" in the shortcut setup. This has solved some (but not all) of the problems I have had trying to run an old 16 bit word processor. It runs adequately (but slowly) in Win2K; there are some deal-killer problems with it in XP. (Under XP it draws all frames opaque over text; and won't print lines or borders on the frames.)
#219476 - 24/06/2004 21:50 Re: Making old programs play nice [Re: tanstaafl.]
Separate Memory Space isn't going to help him here, the problem is that the Win2K version of the operating system has removed an old, undocumented function call from one of the primary DLL files from Win95. I'm not even sure that Win95 compatibility mode will help him here.
#219477 - 24/06/2004 22:06 Re: Making old programs play nice [Re: tfabris]
Damn. That really sucks. I liked that program. Now I wish I had gotten that 98 dual boot working. Guess I got scared when it wiped my boot sector
This sucks. I liked that program because it was very easy to use and very simple and small. I hate Finale and I don't have the damn CD for it so I couldn't use it if I wanted to. Computers really bug me sometimes...
Thanks though, guys.
