#219819 - 08/04/2001 02:42 HPNA affect on Dialup?
phaigh
Hi,
Can someone who's got a Receiver let me know what affect the HPNA stuff has on a dialup internet connection?
I'm not in a broadband area, so I still use dial-up, and I'll be using the Receiver (should I ever get one) via HPNA, pretty much all of the time.
Paul.
RioReceiver - Still Waiting for one in the UK.
Paul Haigh, Reg. 4120 (mk1) 6GB, Blue, 00254 (mk2) 12GB, Red, 00357
#219820 - 09/04/2001 08:23 Re: HPNA affect on Dialup? [Re: phaigh]
HPNA doesn't affect normal telephone/modem operation at all.
#219821 - 09/04/2001 09:41 Re: HPNA affect on Dialup? [Re: rob]
Even for a 56k connection? Those are notoriously twitchy and sensitive to site wiring problems.
#219822 - 09/04/2001 10:13 Re: HPNA affect on Dialup? [Re: tfabris]
phaigh
My thoughts entirely.
I have a very poor connection already, so I'm wary of anything which is going to push me over the edge.
Paul.
#219823 - 09/04/2001 18:27 Re: HPNA affect on Dialup? [Re: tfabris]
/me puts on his Intel Home Networking certification hat
Nope, HPNA technology will in no way interfere with any other telephone line usage, including voice, fax, 56k modem, DSL, home security or anything else.
It works similar to DSL, basicially so high above where normal modems use the line they can't hear a thing.
(I wish I had all the tech specs from that Intel class, but that was at a previous job and they didn't let me take home my training books)
#219824 - 10/04/2001 01:05 Re: HPNA affect on Dialup? [Re: phaigh]
mardibloke
Loc: Penarth, UK
Why not go for Ethernet. Ethernet cards are really cheap ( and you can get one bundled with the Dell Reciever ), then buy a cheap hub.
Rod, UK Mk2 64gig Red S/No.341 Empeg Looking to add a DELL Reciever
Rod, UK
#219825 - 10/04/2001 01:36 Re: HPNA affect on Dialup? [Re: mardibloke]
Why not get cable or DSL? Then you don't have to worry about the 56k .
#219826 - 10/04/2001 10:06 Re: HPNA affect on Dialup? [Re: Roger]
phaigh
Because, of the 3 different broadband solutions in my area - ADSL, Cable and Radio (!) I can have precicsely zero.
Despite being told that I could have all three, and two of them actually sending engineers to install the systems.
ADSL - my line is of too low quality to support ADSL, and BT show exactly zero interest in fixing the line.
Cable - despite being told, repeatedly by NTL that I could have cable internet - I cannot.
Radio (512k!!) - after nearly installing the dish on my house, they then retracted all offer of the service, for no reasonable explaination.
It's a conspiracy I tell you.
Paul
#219827 - 10/04/2001 10:07 Re: HPNA affect on Dialup? [Re: mardibloke]
phaigh
Because there is a telephone point less than 1m away from the stero downstairs and I'd have to completely recable for ethernet.
Now, wireless ethernet - sounds good!
Paul.
#219828 - 10/04/2001 11:14 Re: HPNA affect on Dialup? [Re: phaigh]
I do sympathise. I moved into a place last year on the strength of ntl saying "yeah, we can do cable". Of course, when I'd moved in, and phoned them to install it, they said "No, it's not supported at that property". I had to spend 6 months living without always-on, with the CATV manhole cover only the other side of the road.
I moved.
#219829 - 10/04/2001 14:08 Re: HPNA affect on Dialup? [Re: phaigh]
mardibloke
Loc: Penarth, UK
I tend to live in old rented houses so took the plunge and went wireless a while back. I was concerned about data speeds and also range, but am very happy with the solution I went for. I went for the Lucent ORiNOCO RG-1000 Residential Gateway Startup Kit. This gives you a box ( small ) that has a build in 56k modem. Plug it into you phone line, pop the included PCMCIA Wireless card in Laptop and configure the Gateway with ISP details. You now have a Wireless network with the Gateway doing DHCP sever, NAT and Dial on demand. The Gateway can also plug into Ethernet HUB and offer DHCP server to the wired network and also routing between wireless and wired. Works fine. Cost was around 250ukp+Vat I believe. I also added a Lucent Ethernet adapter so that I can plug my Empeg into a wireless adapter ( guess you would need to do the same for the RioReciever ). So have had the Empeg sat in the Car and been able to communicate with it for PC's in the house network. The adapter is a little pricey at around 150+vat plus you need a PCMCIA Wireless adapter ( 100ukp ??? ).
Rod, UK
#219830 - 10/04/2001 23:58 Re: HPNA affect on Dialup? [Re: Roger]
phaigh
Well, I'll certainly be moving at some point, but it's a difficult one to sell to the better half.
P: We need to move
BH: Why?
P: 'cos I can't get broadband internet...
BH: What's that?
P: *slap*
Paul.
#219831 - 11/04/2001 00:01 Re: HPNA affect on Dialup? [Re: tfabris]
phaigh
Tony,
Since I can't post on the FAQ forum any more - this should be a FAQ posting, I'd think.
Paul.
#219832 - 11/04/2001 00:02 Re: HPNA affect on Dialup? [Re: mardibloke]
phaigh
Hmm, I've already got a router (it's a linux box) and I'm much happier having this instead of a new hardware router.
Is there a solution with just a wireless hub and wireless cards?
Have you got part no.s for the ethernet adapter stuff for the empeg?
This is all starting too look pretty expensive.
Paul.
#219833 - 11/04/2001 01:24 Re: HPNA affect on Dialup? [Re: phaigh]
mardibloke
Loc: Penarth, UK
You do not have to use all the features of the wireless box. You could just use it as a bridge between wireless and your existing ethernet hub.
Reviews here ( and in the reviews links to other wireless product reviews )
http://www.neoseeker.com/Hardware/Products/Orinoco_RG1000
Detail on the Gateway
http://www.wavelan.com/template.html?section=m59&envelope=95&page=129
Ethernet Converter detail
http://www.wavelan.com/template.html?section=m57&envelope=93&page=125
Now that you are not allowed to move house, you suddenly have money to spend
Rod, UK
#219834 - 11/04/2001 05:35 Re: HPNA affect on Dialup? [Re: phaigh]
phaigh
I should clairfy my last post - the *slap* was my hitting my forehead, NOT my girlfriend.
I'm NOT a g/f or wife beater, in fact I've never hit anyone.
Paul.
#219835 - 11/04/2001 09:22 Re: HPNA affect on Dialup? [Re: phaigh]
phaigh
Thanks Tony.
Paul.
