You should be able to order your playlists in Emplode:
- First, select "View/Details" from Emplode's menu.
- Then, select the album playlist you're concerned with.
- One of the columns is labeled "Position". Click on the column header until it sorts by position, ascending.
- Now you should be able to drag that out-of-order track up and down in the list to make it fall into the correct order.
If you do this, and the append-by-source still mis-orders the song when shuffle is turned off, then officially report it as a bug to
[email protected].
