I'm running tRio 0.1.4 on Linux box with JReceiver 0.2.5, serving 3 Rios and working well. However I cannot get the web front end going. I'm trying to connect from another machine running IE, using this url:
http://192.168.2.1:8090/trio-applet.htm where 192.168.2.1 is the address of my Linux box.
I get Applet.Trio not inited in the IE status bar and the following in the Java Console:
Java(TM) Plug-in: Version 1.4.2
Using JRE version 1.4.2 Java HotSpot(TM) Client VM
User home directory = C:\Documents and Settings\david
c: clear console window
f: finalize objects on finalization queue
g: garbage collect
h: display this help message
l: dump classloader list
m: print memory usage
o: trigger logging
p: reload proxy configuration
q: hide console
r: reload policy configuration
s: dump system properties
t: dump thread list
v: dump thread stack
x: clear classloader cache
0-5: set trace level to <n>
Stopped loading ...
Stopping applet ...
Joining applet thread ...
Destroying applet ...
Disposing applet ...
Joined applet thread ...
Quiting applet ...
Unregistered modality listener
Registered modality listener
Invoking JS method: document
Invoking JS method: URL
Referencing classloader:
[email protected], refcount=1
Loading applet ...
Initializing applet ...
Starting applet ...
TRioApplet.init(): null
Parameters. trio-server: 192.168.2.1, rmi-port: 1099
Exporting Remote
Finding remote server
java.security.AccessControlException: access denied( java.net.SocketPermission 127.0.0.1:39000 connect,resolve)
at java.security.AccessControlContext.checkPermission(Unknown Source)
at java.security.AccessController.checkPermission(Unknown Source)
at java.lang.SecurityManager.checkPermission(Unknown Source)
at java.lang.SecurityManager.checkConnect(Unknown Source)
at java.net.Socket.connect(Unknown Source)
at java.net.Socket.<init>(Unknown Source)
at sun.rmi.transport.proxy.RMIDirectSocketFactory.createSocket(Unknown Source)
at sun.rmi.transport.proxy.RMIMasterSocketFactory.createSocket(Unknown Source)
at sun.rmi.transport.tcp.TCPEndpoint.newSocket(Unknown Source)
at sun.rmi.transport.tcp.TCPChannel.createConnection(Unknown Source)
at sun.rmi.transport.tcp.TCPChannel.newConnection(Unknown Source)
at sun.rmi.server.UnicastRef.invoke(Unknown Source)
at trio.TRioServer_Stub.listApplications(Unknown Source)
at trio.applet.TRioApplet.getApplications(Unknown Source)
at trio.applet.TRioApplet.init(Unknown Source)
at sun.applet.AppletPanel.run(Unknown Source)
at java.lang.Thread.run(Unknown Source)
Exception: java.security.AccessControlException: access denied (java.net.SocketPermission 127.0.0.1:39000 connect,resolve)
Finding information ...
Releasing classloader:
[email protected], refcount=0
Done ...
Any ideas?
David
