#229473 - 03/08/2004 09:09 Problems installing emphatic
Globbits
Hi all
So, mistakenly thinking I already had an up to date Hijack, I installed empatic with no joy - turned out I had version 3.93 So, having upgraded to version 4.09, I've tried to install Emphatic again. Still, no joy - the install script fails as follows:
ftp> quote site chmod 755 /usr/local/bin/postinstall.sh
550 Failed.
ftp> quote site chmod 644 emphatic.dtd
200 Okay.
ftp> quote site chmod 644 emphatic.xml
200 Okay.
ftp> quote site exec /usr/local/bin/postinstall.sh /usr/local/bin 1 1 1 1
541 ERROR (rc=1)
ftp> quote site exec rm -f /usr/local/bin/postinstall.sh
541 ERROR (rc=1)
ftp> quote site ro
By the looks of things, /usr/local/bin doesn't exist - if I ftp to the Empeg, all I can find in / is swapfile.
So:
1) Any ideas?
2) Is there a username/password I can use to manually investigate - I'm reasonably FTP-competent....
Ta!
Rich
I don't have a signature - this is a figment of your imagination
#229474 - 03/08/2004 09:55 Re: Problems installing emphatic [Re: Globbits]
Umm. Doesn't it ask you for what directory you want to install it in?
Use dir instead of ls when using FTP. It sends a different command and will show you everything.
Also no . in the Hijack version number
#229475 - 03/08/2004 10:06 Re: Problems installing emphatic [Re: Globbits]
The batch file I shipped with emphatic 2.0 is broken. 2.01 will be out sometime this week to address that and a couple other issues. For now, you can create the directory manually, or install it to some other directory that exists already.
#229476 - 03/08/2004 10:09 Re: Problems installing emphatic [Re: tonyc]
Globbits
Ah, that makes sense
Have re-read the FAQ, and had forgotten that I can use the COM port to do stuff manually. I'll FTP it across, then run the scripts myself
Ta for the responses gents!
#229477 - 03/08/2004 10:49 Re: Problems installing emphatic [Re: Globbits]
Globbits
I give up - you're right - the postinstall script doesn't work at all
What settings do I put into config.ini? I was planning on enabling all options - the auto-launch, the reserve-memory, the shuffly thing and so on, but can only work out some of the settings.
Anyone already got this installed, who can post what these should be? I'm looking for entries like:
EXEC_ONCE
ReserveCache
Thanks in advance
Rich
#229478 - 03/08/2004 11:31 Re: Problems installing emphatic [Re: Globbits]
Just wait for v2.01, probably releasing it tonight.
#229479 - 04/08/2004 07:30 Re: Problems installing emphatic [Re: tonyc]
Globbits
Thanks Tony - actually managed to get it working, but I'll install v2.01 tonight with great glee
Patience? I don't have time for patience!
