#232685 - 06/09/2004 12:49 Problems with jEmplode
JeffreyB
Loc: Cincinnati, OH
I'm running jEmplode 60 with 2.0 on the unit. Whenever I run jEmplode, even if I have made no changes, when exiting I get the message "You have made changes to the device. Would you like to sync now?". If I do a sync, it goes through and rebuilds the database, but next time I run jEmplode, it thinks I've changed something when I haven't. What would casue this? It's stuck thinking that I've made changes, when none were made.
Thanks for the help...
JeffreyB
#232686 - 06/09/2004 13:53 Re: Problems with jEmplode [Re: JeffreyB]
Do you have any orphaned tracks?
#232687 - 06/09/2004 14:51 Re: Problems with jEmplode [Re: tfabris]
JeffreyB
Loc: Cincinnati, OH
"orphaned tracks"????
JeffreyB
#232688 - 06/09/2004 15:22 Re: Problems with jEmplode [Re: JeffreyB]
cushman
Loc: Erie, CO
You know what, I have this problem too. I am thinking maybe it is because I only have soup views, and they get recalculated every time you start jEmplode. Nevertheless, it happens with me, also.
Mark Cushman
#232689 - 06/09/2004 15:23 Re: Problems with jEmplode [Re: JeffreyB]
cushman
Loc: Erie, CO
Search for "refs=0" in the Search view. These orphaned tracks are not referenced by any non-soup playlist. See here for complete tag listing you can search on in jEmplode.
Mark Cushman
#232690 - 06/09/2004 15:40 Re: Problems with jEmplode [Re: cushman]
JeffreyB
Loc: Cincinnati, OH
I also have two soups "All Artists" and "All Songs" sorted alphabetically. These are the two playlists that are always highlited like something was changed in them.
JeffreyB
#232691 - 06/09/2004 18:40 Re: Problems with jEmplode [Re: JeffreyB]
Right, so it's not orphaned tracks, it's what Mark C said. The Jemplode soups get recalculated each time you connect to the player, hence the need to synch. If you didn't use soups and just had playlists, this wouldn't happen.
#232692 - 06/09/2004 20:49 Re: Problems with jEmplode [Re: cushman]
SE_Sport_Driver
Neato! I never knew about some of these:
play_last > daysago(5)
Finds all the tunes that have been played in the last 5 days
refs > 3 and not (tracknr = 2)
Finds all tunes that have a reference count greater than 3 and whose track number does not equal 2.
dirty = "true"
Finds all tunes or playlists that are marked dirty
Are some of these jemplode only?
#232693 - 06/09/2004 23:40 Re: Problems with jEmplode [Re: JeffreyB]
mschrag
Loc: Richmond, VA
Are those soup views on your player or only in jEmplode? Regardless they definitely shouldn't be marked dirty every time ... I'll have to take a look at that one.
#232694 - 06/09/2004 23:40 Re: Problems with jEmplode [Re: SE_Sport_Driver]
mschrag
Loc: Richmond, VA
daysago(5) is jEmplode only ... it's slightly bogus though, because it is only updated when you sync w/ jEmplode, so it's really songs played within the last five days of my last sync
#232695 - 09/09/2004 12:59 Re: Problems with jEmplode [Re: JeffreyB]
mschrag
Loc: Richmond, VA
I never got a response on my followup ... Can you give me more info about this soup? I tried to duplicate this with a search soup on the Empeg along with an All soup in jEmplode-only and could not get this to happen. What is the soup definition of the one that is always being marked dirty?
