#23357 - 05/12/2000 19:23 wireless networked bridge.. I already have one ?
silvercas
i already have this one for our laptops http://www.smc.com/wireless/ . Do I just get another bridge, maybe this one, and plug it into my mk2 and its wireless? Or since I have this one is there a cheaper one that will work with this one?
Alan
#23358 - 06/12/2000 09:24 Re: wireless networked bridge.. I already have one [Re: silvercas]
Smoker_Man
Loc: Calgary, CANADA
It doesn't look like there is a unit that plugs into an existing ethernet port. Unless you can track down a usb wireless ethernet adapter, but then you will have all sorts of fun getting it to work. I have seen a simple unit that connects to an existing ethernet port, I cant remember who but for some reason the Apple Airport jumps into my head, can anyone else verify this?
2x160Gb MkII Lighted Buttons 080000449
#23359 - 06/12/2000 09:31 Re: wireless networked bridge.. I already have one [Re: Smoker_Man]
mardibloke
Loc: Penarth, UK
I'm also interested in wireless, but don't want a bridge in the car really.
Rod, UK Mk2 64gig Red S/No.341
Rod, UK
#23360 - 08/12/2000 01:16 Re: wireless networked bridge.. I already have one [Re: silvercas]
cpayne
Proxim's Symphony line has a wireless-to-Ethernet bridge. Just a box with an antenna and an RJ-45. I have the pre-HomeRF model and it worked well. At the other end you can use their PCMCIA or USB adapters. If you don't care about HRF compatibility there are also PCI and ISA adapters. These are all 1.6 Mbps at 2.4 GHz. http://www.proxim.com/symphony/products/hrf_gateway.shtml
#23361 - 08/12/2000 10:17 Re: wireless networked bridge.. I already have one [Re: cpayne]
I think a great idea would be if empeg designed a "wireless wiring harness", completed with wireless ethernet card already set up to connect with a docked empeg.
Of course, while this all sounds cool, and I know it's possible, I don't see all that much of a use. I use the empeg to play MP3s on my computer now, and it's not very hard to bring inside.
DiGNAN
#23362 - 08/12/2000 14:46 Re: wireless networked bridge.. I already have one [Re: Dignan]
silvercas
okie dokey.. I dont think empeg has to make anything. There is a product like that proxim already made. My thing is I already have a SMC residential gateway smc2052w. I just need to find something that works with this!
#23363 - 09/12/2000 06:07 Re: wireless networked bridge.. I already have one [Re: silvercas]
EmpegRulz
Loc: Cedar Falls, IA USA
I too have the SMC Wireless system in my house. Call me lazy, (you're lazy!) but I'd rather update my empeg without pulling it out of the car. In a perfect world, it would support shared access and I could make it a node on the Internet. :)
John
#23364 - 09/12/2000 19:57 Re: wireless networked bridge.. I already have one [Re: EmpegRulz]
As you may have read in another thread, we're demonstrating this at CES next month using an Airport 802.11 base station. This isn't a shipping commercial solution yet (although it's well within the abilities of many people here to install such a setup) but it does give rise to thought.
Personally, I'm looking forward to 3Gen mobile phones - things will start to get really interesting then!
#23365 - 09/12/2000 21:04 Re: wireless networked bridge.. I already have one [Re: rob]
dionysus
Loc: San Francisco, CA
Hmm.. it won't be until 2015 that US embraces it:(
-mark
...proud to have owned an Empeg since 00287
#23366 - 10/12/2000 10:53 Re: wireless networked bridge.. I already have one [Re: rob]
mardibloke
Loc: Penarth, UK
Does your setup still involve having a wireless bridge ( and hub ? ) at the empeg end of the setup ?
Rod, UK
#23367 - 10/12/2000 18:17 Re: wireless networked bridge.. I already have one [Re: mardibloke]
Yes, the empeg doesn't have a built-in wireless transceiver. Our current demo uses an Apple airport (no need for a hub).
#23368 - 11/12/2000 10:33 Re: wireless networked bridge.. I already have one [Re: rob]
mardibloke
Loc: Penarth, UK
Does the Airport require power - if so what voltage ?
Rod, UK
#23369 - 11/12/2000 14:27 Re: wireless networked bridge.. I already have one [Re: rob]
debauch
Loc: West Midlands, England
Rob, have you managed to work around the problem of the airport base station not talking to other base stations?
Nick.
18Gb blue - s/n 080000299 (original queue position 8724)
-- 18GB red s/n 080000299
#23370 - 12/12/2000 00:16 Re: wireless networked bridge.. I already have one [Re: mardibloke]
mcomb
Loc: San Carlos, CA
The transformer for my Airport is putting out 12 Volts at 1.25 amps. I would assume DC, but it is not listed for some reason.
Hugo mentioned in another thread that it would actually run on anywhere between 8 and 40 volts (don't quote me on that, look it up as I am going based on a somewhat falty memory).
-Mike
