AAhhh! I've got this, too but only when the engine is not running. I've got it even worse. When the volume is at a too high level then sometimes the empeg seems to get too less power so that it quits playing and the display is dark for a short while. Then it boots again and continues playing.
Maybe this is just in winter... Otherwise I have to rething the cabling (ground, battery+) which is now coming from the pre-installed factory unit and not directly from battery... But I've to install the microphone, too (in case the VR comes somewhen..
) so this won't be a problem..
TeeMcBee
Got my Mk2! # 080000143
