Thanks for pointing me in the right direction on the serial boot log here it is
empeg-car bootstrap v1.02 20001106 (
[email protected])flash, let them speak now,5
If there is anyone present who wants to upgrade the flash, let them speak now,ce...:19:54 BST 2002
0000 empeg-car (issue9) board test version
or forever hold their peace...it seems not. Let fly the Penguins of Linux!tWinder Flo
ing Point Emulato
empeg init 0.8998 Corel Comp
I see this is
e000 v1.04image!
Copying kernel...
Mounti
Calling linux kernel...nting first music parti
Uncompressing Linux..................................... done, booting the kernerro
Command line: mem=16m
Ca
Mounting second music parti
l.no
Linux version 2.2.14-rmk5-np17-empeg51 (mac@aphex) (gcc version 2.95.3 200103154k code, 20k reserved, 372k dat
Error mounting partitions (possibly already mou
(release)) #16 Wed Jul 24 18:19:54 BST 2002 hash table e
Remounting first music partit
Processor: Intel StrongARM-1100 revision 11Buffer cach
IP Protocols: ICMP, UDP, TCP
TCP: Hash tables configured (ehash 16384 bhash 16384)now,
ttyS
IrDA (tm) Protocols for Linux-2.2 (Dag Brattli)eir peace...
0000
Signature is 20706d65 'emp '
0100 r
ircomm_tty: virtual tty driver for IrCOMM ( revision:Wed May 26 00:49:11 1999 )dsp audio initialised
0120 testing ic 2 (0-15mb, high word)ialised
Starting kswapd v 1.5
em
01f0 ram test d
SA1100 serial driver version 4.27 with no serial options enabled issued
0220 drive id IBM-DJSA-210
empeg rem
ttyS00 at 0xf8010000 (irq = 15) is a SA1100 UART2c test
03f0 dsp/i2c ok usb ini
0410 temperature is 36te support initialis
hda: IBM-DJSA-210, ATA DISK drive
empeg usb initialised, PDIUSBD12 id 1012er hold their peace...it seems not. Let
empeg state support initialised 0089/88c1 (save to d0004e00).
e000 v1.04
empeg RDS driver initialised 0x00
empeg power-pic driver initialised (first boot)................................. done, booting
RAM disk driver initialized: 16 RAM disks of 4096K size-flash driver initialized
l.
VFS: Mounted root (ex
hda: IBM-DJSA-210, 9590MB w/384kB Cache, CHS=19485/16/63-pump v0.0
Calibrating delay loop... 207.67 BogoMIPSess
empeg-flash driver initializednted r
Memory: 15024k/16M avai
smc chip id/revision 0x4000ed, 372k data, 4k init)
smc_init couldn't find cardhange_root: old root has d_
Partition check:entry hash table
hda: hda1 < hda5 hda6 > hda2 hda3 hda4 okay
Buf
RAMDISK: ext2 filesystem f
Trying to unmount old root ... okayc partition read-only
Linux-
Freeing unused kernel memory: 4k initempeg init 0.8 1999 )ion read-only
I see this is a developer image! virtual tty driver for IrCOMM (
Mounting procMay 26 00:49:
Tried to mount /dev/hda4 as reiserfs but got error : 385:empeg-c
Remounting first music partition read-only0
q
Resto
ttyS02 at
Remounting second music partition read-onlying first music partition read-only
No secondary hard diskemp '
Remounting
Press 'q' now to go into development mode. You HaStarting playerempeg dsp audio initialisedrd disk
empeg dsp
player.cpp : 385:empeg-car 2.00-beta13 2002/07/24.ialiseder loop
empeg remote c
Vcb: 0x4086d000ton initialised
! mp3_decoder.cpp :1049:Failed to find valid sync after seeking to offset 2463id 1012
empeg:/empeg/bin# ip
0000 empeg-car (issue9) board test version 0.05 <
[email protected]>
0100 ram test starting
0110 testing ic 1 (0-15mb, low word)
01f0 ram test done
0200 ide detect
0210 command issued
02f0 ide ok
0300 dsp/i2c test
03f0 dsp/i2c ok
0400 temperature detect
0410 temperature is 38
04f0 temperature ok
0500 usb detect
0510 usb rev 1012
05f0 usb ok
0600 ethernet detect
0611 ethernet not found
0700 cs4231 detect
0710 cs4231 rev a0
07f0 cs4231 ok
00f0 tests complete
