OK so I finally bought a replacement HD for my original 18G, as after 5 years of use it was giving up the ghost.
I followed the disk replacement proc and put alpha8 on it.
I remembered long ago about emplode deleting your music if you copied via drag and drop during the full moon and you weren't wearing your lucky emplode hat. So I was using jemplode and I created a soup all on the player to make sure I wasn't accidentally deleting my mp3's.
At this point I can add via drag and drop, but when I go to create a new playlist, using the all soup and pressing CTL+y to add to playlist, when I sync it says adding <playlist name> gets to 20% and hangs, forever. I am forced to pull the plug and do an FSCK then rebuild the db's.
What is the correct way to manage playlists in alpha 8? I remember a post about downgrading to 2.0 to mess w playlists then adding alpha 8 back on. Is this still true?
I haven't messed w my playlists in 3 years what is the best way to do this?
___
John Turner
"It's easier to ask for forgiveness than to ask for permission"
