e000 v1.04
Copying kernel...
Calling linux kernel...
Linux version 2.2.17-rmk5-np17-empeg52-hijack-v417 (
[email protected]) (gcc version 2.95.3 20010315 (release)) #2 Sat Jan 15 19:12:21 EST 2005
Checking for extra DRAM:
c1000000: passed.
c1100000: passed.
c1200000: passed.
c1300000: passed.
c1400000: passed.
c1500000: passed.
c1600000: passed.
c1700000: passed.
c1800000: passed.
c1900000: passed.
c1a00000: passed.
c1b00000: passed.
c1c00000: passed.
c1d00000: passed.
c1e00000: passed.
c1f00000: passed.
c2000000: passed.
c2100000: passed.
c2200000: passed.
c2300000: passed.
c2400000: passed.
c2500000: passed.
c2600000: passed.
c2700000: passed.
c2800000: passed.
c2900000: passed.
c2a00000: passed.
c2b00000: passed.
c2c00000: passed.
c2d00000: passed.
c2e00000: passed.
c2f00000: passed.
c3000000: passed.
c3100000: passed.
c3200000: passed.
c3300000: passed.
c3400000: passed.
c3500000: passed.
c3600000: passed.
c3700000: passed.
c3800000: passed.
c3900000: passed.
c3a00000: passed.
c3b00000: passed.
c3c00000: passed.
c3d00000: passed.
c3e00000: passed.
c3f00000: passed.
empeg-car player (hardware revision 9, serial number 10101539) 64MB DRAM
Command line: mem=16m
Memory: 63676k/64M available (984k code, 20k reserved, 852k data, 4k init)
Dentry hash table entries: 8192 (order 4, 64k)
Buffer cache hash table entries: 65536 (order 6, 256k)
Page cache hash table entries: 16384 (order 4, 64k)
Linux NET4.0 for Linux 2.2
IP Protocols: ICMP, UDP, TCP
TCP: Hash tables configured (ehash 65536 bhash 65536)
Starting kswapd v 1.5
Signature is 206f6972 'rio '
Tuner: loopback=0, ID=-1
empeg display initialised.
empeg dsp audio initialised
empeg dsp mixer initialised
empeg dsp initialised
empeg state support initialised 0089/88c1 (save to d0005c80).
empeg RDS driver initialised
empeg single channel IDE
Probing primary interface...
hda: IBM-DARA-206000, ATA DISK drive
hda: IBM-DARA-206000, 5729MB w/418kB Cache, CHS=12416/15/63
smc chip id/revision 0x3349
smc9194.c:v0.12 03/06/96 by Erik Stahlman (
[email protected])
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:22:06:03
Partition check:
empeg-pump v0.03 (19980601)
Press Ctrl-A to enter pump...•Ô•j½Õ¹Ñ•‘�ɽ½Ñ�¡•áÑÉ�™¥±•ÍåÍÑ•µ¥�É•…‘½¹±å¹)5ÿchange_root: old root has d_count=1
Mounting proc
No secondary hard disk
Press 'q' now to go into development mode. You Have Zero Seconds To ComðStarting player
Timezone: Atlantic/South_Georgia
hijack: removed menu entry: "Serial Port Assignment"
khttpd: listening on port 80
kftpd: listening on port 21
Vcb: 0x4086d000
