#261900 - 31/07/2005 14:41 Dead Empeg
Nosferatu
Loc: France, Champagne
After past 3 years service my Empeg MKIIa Hard Disk died ....
I searched on the forums for the info but didnt find it.
What hard drive model and how to reinstall a new Os on it ?
Thanks for your help,
Empeg IIa - 10 Gb - Red Fascia - Tuner, the day is coming - I Will Strike From the Grey -
#261901 - 31/07/2005 14:50 Re: Dead Empeg [Re: Nosferatu]
SE_Sport_Driver
Sorry to hear that!
A drive upgrade is pretty simple.
http://www.riocar.org/modules.php?op=modload&name=Drive_Upgrade&file=index
I used to use the IBM Travelstar drives but Hitachi (?) bought their 2.5" drive business so now I use Hitachi Travelstar drives. You can get good deals here: www.pricewatch.com Avoid Toshiba drives.
#261902 - 31/07/2005 15:20 Re: Dead Empeg [Re: SE_Sport_Driver]
Nosferatu
Thanks for the Quick answer SE, i searched for 2.5 " HDD but the 2 brands availables are : Samsung and Fujitsu.(I experienced many problems with Fuji HDD at work ...)
So I will order a Samsung .....
But the excellent Tony's FAQ says to use the Disk Builder but I currently use Linux .....
Is is possible to apply the .upgrade with Jemplode ?
#261903 - 31/07/2005 15:55 Re: Dead Empeg [Re: Nosferatu]
Nosferatu
Found the empegtoool that will do the job ....
I'll try as sons I receive my HDD .....
#261904 - 01/08/2005 05:09 Re: Dead Empeg [Re: Nosferatu]
Nosferatu
Finally, I found the Famous Hitachi Travelstar and ordered one ....
Took the 8 Mo Buffer as the original had only 2 Mo.
Hope it will be quickly in my hands.
#261905 - 04/09/2005 17:45 Re: Dead Empeg [Re: Nosferatu]
Nosferatu
I got finally the new 40 GB HD.
tried wth the old HD, that makes some noise ( cri cri cri cri..) but starts but I have the same error mesage NO Hard Disk found !!!
I read the No hard Disk Foun Contact support FAQ , and with the new HD I still have the eroor mesage:
No Hard Disk found ...
Don't know what to do ....
Edited by Nosferatu (04/09/2005 17:47)
#261906 - 04/09/2005 19:07 Re: Dead Empeg [Re: Nosferatu]
Apologies for not being helpful, but...
A thread titled "Dead Empeg" by Nosferatu.
Made me grin like a loon!
#261907 - 04/09/2005 19:48 Re: Dead Empeg [Re: Nosferatu]
Boot log..
#261908 - 05/09/2005 07:35 Re: Dead Empeg [Re: Nosferatu]
schofiel
Well, have you been through the whole FAQ relating to diagnosing hard drive problems? The standard problem is usually a bad cable - you don't mention if you have done any of this.
#261909 - 05/09/2005 09:02 Re: Dead Empeg [Re: schofiel]
Nosferatu
yeah, right I did not mention ...
I crimped the cable but no success.
I think this is a very bad cable ,
I tried to take a look on Eutronix but site is not available.
so now my question is where to buy another ?
ps : Mark , I will grab the boot log ... and put it on the Forum
#261910 - 05/09/2005 09:26 Re: Dead Empeg [Re: Nosferatu]
Nosferatu
\0x00
empeg-car bootstrap v1.02 20001106 ([email protected])
e000 v1.04
Copying kernel...
Calling linux kernel...
Linux version 2.2.17-rmk5-np17-empeg52-hijack-v429 ([email protected]) (gcc version 2.95.3 20010315 (release)) #2 Tue May 10 20:39:19 EDT 2005
Added temporary pagedir entry for flash memory access
Checking for extra DRAM:
c1000000: wrote ffffffff, read e2811004
empeg-car player (hardware revision 9, serial number 10102101) 16MB DRAM
Command line: mem=16m
Memory: 15012k/16M available (984k code, 20k reserved, 364k data, 4k init)
Linux NET4.0 for Linux 2.2
IP Protocols: ICMP, UDP, TCP
Starting kswapd v 1.5
Signature is 636f6972 'rioc'
Found custom animation at offset 0x9a38c
Tuner: loopback=0, ID=-1
Scheduling custom logo.
empeg display initialised.
empeg dsp audio initialised
empeg dsp mixer initialised
empeg dsp initialised
empeg state support initialised 0089/88c1 (save to d0005580).
empeg RDS driver initialised
empeg single channel IDE
Probing primary interface...
hda: HTS541040G9AT00, ATA DISK drive
hda: HTS541040G9AT00, 38154MB w/7539kB Cache, CHS=4864/255/63
smc chip id/revision 0x3349
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:22:08:35
Partition check:
hda: unknown partition table
RAMDISK: Loading 320 blocks [1 disk] into ram disk... |\0x08/\0x08-\0x08\\0x08|\0x08/\0x08-\0x08\\0x08|\0x08/\0x08-\0x08\\0x08|\0x08/\0x08-\0x08\\0x08|\0x08/\0x08-\0x08\\0x08done.
empeg-pump v0.03 (19980601)
Press Ctrl-A to enter pump...\0x00X]]Y[\]H]\0x0b)kk«kÍ\0x81\0x89\0x95å½¹\0x91\0x81\0x95¹\0x91\0x81½\0x99\0x81\0x91\0x95Ù¥\0x8d\0x95)5\0x7fL&'¦\0x93\0x02\0x92ÝõÁ±\0x81Ý\0x85¹Ñõɱ\0x81±¥µ¥ÑõÁ)5\0x1fV\0x96\0x17\0x12Ó\0x93\0x82ª\0x02\0x12±­Í¥é\0x95õÅÁÉÑ\0x81\0x89±½\0x8d­¹ÉõÅ\0x81Í\0x95\0x8dѽÉõÉ\0x81Í¥é\0x95õÅÁÉÑ\0x81\0x8d½Õ¹ÑõÅ)5\0xffEXT2-fs: unable to read superblock
Kernel panic: VFS: Unable to mount root fs on 03:05
\0x00
Do I simply need to apply the Disk Builder ?
#261911 - 05/09/2005 09:30 Re: Dead Empeg [Re: Nosferatu]
Is this with the new hard drive? It looks like it was not built - it cannot find the root partition and is reading a bad partition table. Either the cable is bad, off by one pin, or the drive was new and not built. I would say, yes, reapply the disk builder (assuming this is a new drive with no data on it you want to save) and then reload the .upgrade file.
#261912 - 05/09/2005 09:59 Re: Dead Empeg [Re: pgrzelak]
Nosferatu
Yes it is a new hard drive, but I cannot apply the disk builder .... it does not find the unit ...
But it's possible i do it in a wrong way.
I'm under Linux and type this :
./upgclient /mnt/david/Empeg/car2-builder-20011022.upgrade
As my empeg unit is connected to ttys0.
Here is the message I have when trying to apply Disk Builder :
empegupgrade: Using upgrade file 'car2-builder-20011022.upgrade' to device '/dev/ttyS0' (115200 baud)
Checking upgrade file integrity [100%]
Pumping player software
Finding unit [100%]
ERROR: 5 empeg unit not found
Upgrade aborted due to errors [ 0%]
Upgrade failed :-(
Upgrade failed with error 0x80040056
Edited by Nosferatu (05/09/2005 10:31)
#261913 - 05/09/2005 11:59 Re: Dead Empeg [Re: Nosferatu]
Finding unit
Leave the empeg powered off until it gets to this stage, and then plug in the power...
#261914 - 05/09/2005 12:12 Re: Dead Empeg [Re: Roger]
Nosferatu
Thanks for the quick answer I tried when the upgrade prog is trying to find unit but the same problem appears when I plug the power supply to empeg....
On the boot log :
er hold my son!, I must warn you that the Flash has beeeh
?eh
May I connect as soon as possible when the Finding unit Phasis starts or I have time to do ?
Edited by Nosferatu (05/09/2005 12:23)
#261915 - 05/09/2005 12:49 Re: Dead Empeg [Re: Nosferatu]
Pretty certain you don't plug it in until the message asks you to do so. Can't remember off the top of my head, but I seem to recall just following some instruction like that.
#261916 - 05/09/2005 13:01 Re: Dead Empeg [Re: Nosferatu]
Looks like it. Need to apply the Disk Builder. But that requires getting a working serial connection to the boot firmware, always a tricky operation on some PCs, it seems.
#261917 - 05/09/2005 16:56 Re: Dead Empeg [Re: mlord]
Nosferatu
My serial works okk because I can read the boot log with no problem at all ......
#261918 - 05/09/2005 18:46 Re: Dead Empeg [Re: Nosferatu]
Yeah, but the downloader programs (for installing the upgrader kernel etc..) tend to be fussier than one would expect..
Good luck!
#261919 - 05/09/2005 19:42 Re: Dead Empeg [Re: mlord]
Nosferatu
yeah you're right Mark , but now I don't know what to do ....
#261920 - 05/09/2005 20:23 Re: Dead Empeg [Re: Nosferatu]
Try a different (e.g. friend's) PC?
