#261900 - 31/07/2005 14:41
Dead Empeg
Loc: France, Champagne
After past 3 years service my Empeg MKIIa Hard Disk died ....  I searched on the forums for the info but didnt find it. What hard drive model and how to reinstall a new Os on it ? Thanks for your help,
Empeg IIa - 10 Gb - Red Fascia -
Tuner, the day is coming
- I Will Strike From the Grey -
#261902 - 31/07/2005 15:20
Re: Dead Empeg
[Re: SE_Sport_Driver]
Thanks for the Quick answer SE, i searched for 2.5 " HDD but the 2 brands availables are : Samsung and Fujitsu.(I experienced many problems with Fuji HDD at work ...)
So I will order a Samsung .....
But the excellent Tony's FAQ says to use the Disk Builder but I currently use Linux ..... Is is possible to apply the .upgrade with Jemplode ?
#261903 - 31/07/2005 15:55
Re: Dead Empeg
[Re: Nosferatu]
Found the empegtoool that will do the job ....  I'll try as sons I receive my HDD .....
#261904 - 01/08/2005 05:09
Re: Dead Empeg
[Re: Nosferatu]
Finally, I found the Famous Hitachi Travelstar and ordered one ....  Took the 8 Mo Buffer as the original had only 2 Mo. Hope it will be quickly in my hands.
#261905 - 04/09/2005 17:45
Re: Dead Empeg
[Re: Nosferatu]
I got finally the new 40 GB HD.
tried wth the old HD, that makes some noise ( cri cri cri cri..) but starts but I have the same error mesage NO Hard Disk found !!!
I read the No hard Disk Foun Contact support FAQ , and with the new HD I still have the eroor mesage:
No Hard Disk found ...
Don't know what to do ....
Edited by Nosferatu (04/09/2005 17:47)
#261906 - 04/09/2005 19:07
Re: Dead Empeg
[Re: Nosferatu]
Apologies for not being helpful, but...
A thread titled "Dead Empeg" by Nosferatu.
Made me grin like a loon!
#261907 - 04/09/2005 19:48
Re: Dead Empeg
[Re: Nosferatu]
#261908 - 05/09/2005 07:35
Re: Dead Empeg
[Re: Nosferatu]
Well, have you been through the whole FAQ relating to diagnosing hard drive problems? The standard problem is usually a bad cable - you don't mention if you have done any of this.
#261909 - 05/09/2005 09:02
Re: Dead Empeg
[Re: schofiel]
yeah, right I did not mention ...
I crimped the cable but no success. I think this is a very bad cable ,
I tried to take a look on Eutronix but site is not available.
so now my question is where to buy another ?
ps : Mark , I will grab the boot log ... and put it on the Forum
#261910 - 05/09/2005 09:26
Re: Dead Empeg
[Re: Nosferatu]
\0x00 empeg-car bootstrap v1.02 20001106 (hugo@empeg.com) If there is anyone present who wants to upgrade the flash, let them speak now, or forever hold their peace...it seems not. Let fly the Penguins of Linux!
e000 v1.04 Copying kernel... Calling linux kernel... Uncompressing Linux..................................... done, booting the kernel. Linux version 2.2.17-rmk5-np17-empeg52-hijack-v429 (hijack@rtr.ca) (gcc version 2.95.3 20010315 (release)) #2 Tue May 10 20:39:19 EDT 2005 Processor: Intel StrongARM-1100 revision 11 Added temporary pagedir entry for flash memory access Checking for extra DRAM: c1000000: wrote ffffffff, read e2811004 NetWinder Floating Point Emulator V0.94.1 (c) 1998 Corel Computer Corp. empeg-car player (hardware revision 9, serial number 10102101) 16MB DRAM Command line: mem=16m Calibrating delay loop... 207.67 BogoMIPS Memory: 15012k/16M available (984k code, 20k reserved, 364k data, 4k init) Dentry hash table entries: 2048 (order 2, 16k) Buffer cache hash table entries: 16384 (order 4, 64k) Page cache hash table entries: 4096 (order 2, 16k) POSIX conformance testing by UNIFIX Linux NET4.0 for Linux 2.2 Based upon Swansea University Computer Society NET3.039 NET4: Linux TCP/IP 1.0 for NET4.0 IP Protocols: ICMP, UDP, TCP TCP: Hash tables configured (ehash 16384 bhash 16384) IrDA (tm) Protocols for Linux-2.2 (Dag Brattli) Starting kswapd v 1.5 SA1100 serial driver version 4.27 with no serial options enabled ttyS00 at 0xf8010000 (irq = 15) is a SA1100 UART ttyS01 at 0xf8050000 (irq = 17) is a SA1100 UART ttyS02 at 0xf8030000 (irq = 16) is a SA1100 UART Signature is 636f6972 'rioc' Found custom animation at offset 0x9a38c Tuner: loopback=0, ID=-1 Scheduling custom logo. empeg display initialised. empeg dsp audio initialised empeg dsp mixer initialised empeg dsp initialised empeg audio-in initialised, CS4231A revision a0 empeg remote control/panel button initialised. empeg usb initialised, PDIUSBD12 id 1012 empeg state support initialised 0089/88c1 (save to d0005580). empeg RDS driver initialised empeg power-pic driver initialised (first boot) RAM disk driver initialized: 16 RAM disks of 4096K size empeg single channel IDE Probing primary interface... hda: HTS541040G9AT00, ATA DISK drive hda: HTS541040G9AT00, ATA DISK drive hda: HTS541040G9AT00, ATA DISK drive hda: HTS541040G9AT00, ATA DISK drive hda: HTS541040G9AT00, ATA DISK drive hda: HTS541040G9AT00, ATA DISK drive ide0 at 0x000-0x007,0x038 on irq 6 hda: HTS541040G9AT00, 38154MB w/7539kB Cache, CHS=4864/255/63 empeg-flash driver initialized smc chip id/revision 0x3349 smc9194.c:v0.12 03/06/96 by Erik Stahlman (erik@vt.edu)
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:22:08:35 Partition check: hda: unknown partition table RAMDISK: ext2 filesystem found at block 0 RAMDISK: Loading 320 blocks [1 disk] into ram disk... |\0x08/\0x08-\0x08\\0x08|\0x08/\0x08-\0x08\\0x08|\0x08/\0x08-\0x08\\0x08|\0x08/\0x08-\0x08\\0x08|\0x08/\0x08-\0x08\\0x08done. EXT2-fs warning: checktime reached, running e2fsck is recommended VFS: Mounted root (ext2 filesystem). empeg-pump v0.03 (19980601) Press Ctrl-A to enter pump...\0x00X]]Y[\]H]\0x0b)kk«kÍ\0x81\0x89\0x95å½¹\0x91\0x81\0x95¹\0x91\0x81½\0x99\0x81\0x91\0x95Ù¥\0x8d\0x95)5\0x7fL&'¦\0x93\0x02\0x92ÝõÁ±\0x81Ý\0x85¹Ñõɱ\0x81±¥µ¥ÑõÁ)5\0x1fV\0x96\0x17\0x12Ó\0x93\0x82ª\0x02\0x12±Í¥é\0x95õÅÁÉÑ\0x81\0x89±½\0x8d¹ÉõÅ\0x81Í\0x95\0x8dѽÉõÉ\0x81Í¥é\0x95õÅÁÉÑ\0x81\0x8d½Õ¹ÑõÅ)5\0xffEXT2-fs: unable to read superblock Kernel panic: VFS: Unable to mount root fs on 03:05 \0x00
Do I simply need to apply the Disk Builder ?
#261911 - 05/09/2005 09:30
Re: Dead Empeg
[Re: Nosferatu]
Is this with the new hard drive? It looks like it was not built - it cannot find the root partition and is reading a bad partition table. Either the cable is bad, off by one pin, or the drive was new and not built. I would say, yes, reapply the disk builder (assuming this is a new drive with no data on it you want to save) and then reload the .upgrade file.
#261912 - 05/09/2005 09:59
Re: Dead Empeg
[Re: pgrzelak]
Yes it is a new hard drive, but I cannot apply the disk builder .... it does not find the unit ...
But it's possible i do it in a wrong way.
I'm under Linux and type this :
./upgclient /mnt/david/Empeg/car2-builder-20011022.upgrade
As my empeg unit is connected to ttys0.
Here is the message I have when trying to apply Disk Builder :
empegupgrade: Using upgrade file 'car2-builder-20011022.upgrade' to device '/dev/ttyS0' (115200 baud)
Checking upgrade file integrity [100%]
Pumping player software
Finding unit [100%]
ERROR: 5 empeg unit not found
Upgrade aborted due to errors [ 0%]
Upgrade failed :-(
Upgrade failed with error 0x80040056
Edited by Nosferatu (05/09/2005 10:31)
#261913 - 05/09/2005 11:59
Re: Dead Empeg
[Re: Nosferatu]
Quote: Finding unit
Leave the empeg powered off until it gets to this stage, and then plug in the power...
#261914 - 05/09/2005 12:12
Re: Dead Empeg
[Re: Roger]
Thanks for the quick answer I tried when the upgrade prog is trying to find unit but the same problem appears when I plug the power supply to empeg....
On the boot log :
er hold my son!, I must warn you that the Flash has beeeh
?eh
May I connect as soon as possible when the Finding unit Phasis starts or I have time to do ?
Edited by Nosferatu (05/09/2005 12:23)
#261915 - 05/09/2005 12:49
Re: Dead Empeg
[Re: Nosferatu]
Pretty certain you don't plug it in until the message asks you to do so. Can't remember off the top of my head, but I seem to recall just following some instruction like that.
#261916 - 05/09/2005 13:01
Re: Dead Empeg
[Re: Nosferatu]
Quote: Do I simply need to apply the Disk Builder ?
Looks like it. Need to apply the Disk Builder. But that requires getting a working serial connection to the boot firmware, always a tricky operation on some PCs, it seems.
#261917 - 05/09/2005 16:56
Re: Dead Empeg
My serial works okk because I can read the boot log with no problem at all ......
#261918 - 05/09/2005 18:46
Re: Dead Empeg
[Re: Nosferatu]
Quote: My serial works okk because I can read the boot log with no problem at all ......
Yeah, but the downloader programs (for installing the upgrader kernel etc..) tend to be fussier than one would expect..
Good luck!
