0) Creater a new user, add it to the administrators group, logoff and logon with the new user.
1) Create a new folder to host the profiles. For example: G:\doc-and-settings
2) Copy all existing profiles from the %systemdrive%\Documents and Settings folder to the folder you just created.
Xcopy "c:\documents and settings" "G:\doc-and-settings" /S /E /V /C /G /H /R /K /O /X /Y
3) Launch regedit.exe, and go to HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\ProfileList.
Double-click ProfilesDirectory. Enter the path to the new folder (G:\doc-and-serttings), and click OK.
4) In the same location of the registry, you will see there are a numbr of "subfolders". There's one for each local user. Click on each and modify the value of
"ProfileImagePath".
5) Logoff, logon with any other admin user, and delete the admin user you created at 0).
