#268800 - 04/11/2005 06:20 Jemplode Request: no db rebuild if only editing config.ini
matthew_k
The subject line says it all. Emplode doesn't rebuild the db if you havn't added music. Makes debugging ir_translates a pain with jemplode, as it takes a Good Long While for each iteration.
Definitly a "if it's easy while you're already messing with the code" request.
#268801 - 04/11/2005 08:14 Re: Jemplode Request: no db rebuild if only editing config.ini [Re: matthew_k]
You could install an editor and just edit the file directly? You'd have to connect to the empeg via serial or telnet however.
#268802 - 04/11/2005 08:59 Re: Jemplode Request: no db rebuild if only editing config.ini [Re: tman]
I think he's aware of the alternate methods to edit the file, he's just noticed that there's something specifically in Jemplode that could use a bit of a code tweak. At least that's the way I interpreted it.
