Found the past post to the SMB TAR file URL site, but it is not working. Very interested in browsing the empeg via Win Explorer. Can you repost the TAR/URL? What are the tweaks that you hinted at?
Here is the same pacakge I posted some months ago. This will not be a permanent location now either, but it'll stay there for a while.
Please note that the package is nowhere near plug-and-play installation. It only provides the Samba-2.07 package which is modified to compile for empeg platform. The package also includes the binaries, so it's not necessary to recompile it.
One of the problems you probably end up seeing is that you must have the drive RW mounted while you are running Samba. As this is a bit risky, I've moved my
/etc,
/usr and
/var directories into the scratch partition which in my configuration is always RW mounted (then only symlinking those from the main partition to the scratch partition). Also, if you want to use Samba before empeg-player has negotiated IP address, you need to use
dhcpcd or similar DHCP client to obtain IP address.
Kim
