#277191 - 10/03/2006 07:37 FID limits?
HOT2N
Loc: New Jersey, United States
I recall reading in another post that a MKI with 56GB of disk may run out of ram to hold the FID tags, can such a thing happen to the MKII, and what is the limit of a stock MKII Empeg car with v2.0 firmware?
Also what can the MKII be upgraded to again?
I was N2TOH, but forgot my password and need help resetting it. I get no reply from emails sent to the admin. 20GB MK2 Green 080000171
#277192 - 11/03/2006 03:26 Re: FID limits? [Re: HOT2N]
It's not the disk space so much as the number of tunes on the player. If you encode all your tunes at a high bitrate, then 56 gigs will hold fewer tunes than if you'd encoded them at lower bit rates.
The number of tunes that gives the problem also seems to depend upon how much tag information is filled out, such as data residing in comment tags (if I recall correctly). So the exact number of tunes isn't the same for any two players, either. But I've heard reports of some players having database-size-trouble when the number of tunes gets into the teens of thousands.
#277193 - 11/03/2006 04:14 Re: FID limits? [Re: tfabris]
HOT2N
I think I smell the need for a potential feature in empeg management software.
Have the software analyse the FID info and calculate the needed RAM on the player before loading new tunes, and maybe estimate remaining space for FIDs via the trend in track info per song.
#277194 - 11/03/2006 15:35 Re: FID limits? [Re: tfabris]
SE_Sport_Driver
Because of this, part of my upload process involves clearing all comment tags.
#277195 - 11/03/2006 16:04 Re: FID limits? [Re: SE_Sport_Driver]
SonicSnoop
Loc: Triangle, VA
I wonder how bad the lyrics added to mp3s affect this
#277196 - 11/03/2006 16:59 Re: FID limits? [Re: SE_Sport_Driver]
HOT2N
comment tags being everything other than the basic tune name, artist, album, year?
#277197 - 11/03/2006 17:06 Re: FID limits? [Re: HOT2N]
Comment tags being, everything in the field labeled "COMMENT".
#277198 - 11/03/2006 17:07 Re: FID limits? [Re: SonicSnoop]
They shouldn't, unless the lyrices are sitting inside the COMMENT field. Lyrics are generally a different tag field than COMMENT.
