#28037 - 13/03/2001 09:08 Pioneer Remote
ineedcolor
Loc: Windsor, Ontario Canada
Help! Seeing the recent posts on installing the IR kernel for the Pioneer streeing wheel remote, I see that it may be fairly involved to carry out the procedure. I am majorly Linux-challenged, is there anyone one willing to do the hack from start to finish and put it all into one post with a step-by-step instruction? I would really love to use my remote but I'm not ready to risk screwing with my new player just yet due to my ineptness with Linux coding....Thanks - John
Technoweenie
12 GB Blue / Red MK2
#28038 - 13/03/2001 11:18 Re: Pioneer Remote [Re: ineedcolor]
Even if you turn out to be hopelessly inept, you shouldn't be able to break anything. The original kernel is recoverable, simply by loading a .upgrade file.
There's really very little risk involved.
#28039 - 13/03/2001 11:37 Re: Pioneer Remote [Re: Roger]
ineedcolor
Thanks Roger...BTW, any chance of you guys putting the IR kernel codes for the Pioneer remote into a later software version due to it's popularity as an alternative to the Kenwood/Rio? (maybe/hopefully)
Technoweenie
#28040 - 13/03/2001 14:46 Re: Pioneer Remote [Re: ineedcolor]
That would also require UI in emplode and code on the player to enable/disable the feature. People with Pioneer head units would not be too happy otherwise!
Since the tuner module will provide an interface for a wired Sony stalk controller I suspect that out-of-the-box support for other remotes will not happen.
#28041 - 14/03/2001 04:00 Re: Pioneer Remote [Re: rob]
Henno
Loc: Meije, Netherlands
Rob, do you think you can already release connect details?
(I'd like to have my car wired-up for this Sony controller when the tuner module gets in )
Henno
mk2 6 nr 6
#28042 - 14/03/2001 07:25 Re: Pioneer Remote [Re: Henno]
It's a 3.5mm stereo jack (socket on the tuner).
#28043 - 15/03/2001 03:01 Re: Pioneer Remote [Re: altman]
Henno
Which means that the radio module will accepts the jack that comes with the remote. I'll start mounting the thing. Thanks
Henno
mk2 6 nr 6
