#282339 - 02/06/2006 07:31 question about the IDE cables from Eutronix
nikko
I see they sell two versions. A "normal" size one and one that is 2" longer. Is one preferable to the other? What's the extra length for?
Thanks in advance for any help you can provide.
#282340 - 02/06/2006 07:39 Re: question about the IDE cables from Eutronix [Re: nikko]
It's hopefully to prevent a problem where long-term repeated movement of the hard disk's shock-mount tray causes the IDE header to be pulled off of the motherboard.
Essentially, it's to help prevent a repetitive stress injury.
#282341 - 02/06/2006 16:01 Re: question about the IDE cables from Eutronix [Re: tfabris]
schofiel
The problem is simply cured by increasing the MB to primary connector distance.
