#286255 - 31/08/2006 18:23 Anyone built a homebrew lirc IR receiver?
I've been using an IRman for years but recently bought a Sky Navigator remote to use with my mythbox, the reason being was that it had a keyboard which I thought would be useful. Anyways, the remote and IRman don't get on so I looked for a replacement. The IRman uses lirc anyway so I thought I'd build the 'homebrew' serial receiver.
I had all bar one of the components hanging around so I stuck a TSOP1738 on a recent CPC order and decided to build one.
The details are here:
http://www.lirc.org/receivers.html
Schematic is here:
IC1 = TSOP 1738
+-----------------------+ 3 R1 (4k7)
| data -> +--------------------------------+------------o DCD
| | _______ |
| ______________ | | 78L05 | | | D1 (1N4148)
| / | +-----+-----|OUT IN|--+ | |
| ( | 2 | | + |__GND__| | | | /|
| \______________ + +----+ ----- | +----+------|< |--o RTS
| | ----- | IC2 | \|
| | 1 | |
| - +----------+---------+------------------------o GND
+-----------------------+ C1 (4.7µF)
To put it bluntly, it doesn't work. The serial port of every machine I have at home (7 or 8, must try harder) is seemingly unable to supply the voltage under load resulting in just over 3V going into the TSOP, not enough, the minimum is 4.5V. So, I decide to power it off the internal 5v rail via one of the molex's. The reg finally puts out a good 5V but this then shows up another problem, the data line is then tied high at 10V (the TSOP is running at 5 remember) and it melts the bugger (good job i bought a few).
Am I being an idiot, or is this design ill-conceived? Given this circuit is basically a reg, a cap, a diode and a resistor, it should work fine.... and they do, in isolation. Just bringing it all together seems to be the problem.
#286256 - 31/08/2006 19:32 Re: Anyone built a homebrew lirc IR receiver? [Re: andym]
BAKup
Loc: Houston, TX
I've built that same circit, and had the same issues, I gave up and picked up a cheap PC remote setup off Ebay that works with lirc, after searching, I can't find the same setup, but I did find someone who's selling pre-made recievers for a decent price.
http://cgi.ebay.com/Serial-Infrared-Remo...1QQcmdZViewItem
--Ben
78GB MkIIa, Dead tuner.
#286257 - 31/08/2006 20:02 Re: Anyone built a homebrew lirc IR receiver? [Re: andym]
I must admit I too had problem building my own, I just splashed out and bought a USB-UIRT and it has functioned perfectly all the time I have had it, it also has a pretty powerful IR transmitter, which comes in handy when automating things via the HTPC. It also handles cable TV boxes etc...
Cris.
#286258 - 01/09/2006 05:33 Re: Anyone built a homebrew lirc IR receiver? [Re: andym]
sn00p
Loc: South London
It doesn't look very clever, that chip is a TTL/cmos device and is being exposed directly to RS232 voltages. I went to the site and there is a more comprehensive version of that circuit which uses transistors to buffer/protect the chip from these voltages, you might want to consider using that - or get a max232 and a couple of caps and use that.
#286259 - 01/09/2006 09:57 Re: Anyone built a homebrew lirc IR receiver? [Re: sn00p]
All the ebay ones are based upon a design by a guy called Igor Cesko. I've got two good TSOPs left and all the bits to build so I'll probably give it a go first.
#286260 - 01/09/2006 19:03 Re: Anyone built a homebrew lirc IR receiver? [Re: andym]
Well, I doff my cap to Mr. Cesko, he certainly knows what he's doing. Just got to program all my key events into MythTV now.
#286261 - 01/09/2006 19:52 Re: Anyone built a homebrew lirc IR receiver? [Re: sn00p]
No. There is regulator to regulate RTS down to +5V as a power supply. DCD is an input to the PC. So it's all legit. Although it's not really to the standard PCs almost always will understand +5v/0V instead of proper TTL.
Personally I built a UIR for my MythTV but that requires a PIC programmer. After quite a few years it went a bit flaky though and I ended up buying a Microsoft MCE remote and USB receiver which works just fine under Linux.
#286262 - 07/09/2006 15:43 Re: Anyone built a homebrew lirc IR receiver? [Re: andym]
I've built 3 of them and they're all fine
This is my favourite:
Edited by LittleBlueThing (07/09/2006 16:08)
#286263 - 17/09/2006 01:50 Re: Anyone built a homebrew lirc IR receiver? [Re: andym]
siberia37
Loc: Tacoma,WA
I made one. I took the easy way out and dropped the 78L05 and the cap- I draw the 5V directly from the PC power supply via a floppy power connector. It works fine never had any trouble with it, although I didn't use it for very long.
