#288078 - 12/10/2006 01:59 Manual disk build instructions ?
Does anyone have a link to instructions for manual disk creation ? All I can find are bad links. The disk builder is not working for me I suspect because I am using a USB to serial adapter so I want to try the manual build.
#288079 - 12/10/2006 05:26 Re: Manual disk build instructions ? [Re: msaeger]
Assuming that you're talking about the two pages on my website, it's probably my bad. I moved my website.
And I managed to turn off the clever mod_rewrite redirection thing I had going.
So, for future reference, here are the correct links:
http://www.differentpla.net/content/2004/03/partition-empeg
http://www.differentpla.net/content/2004/03/format-empeg
#288080 - 12/10/2006 10:28 Re: Manual disk build instructions ? [Re: Roger]
Thanks hopefully I can get it done tonight.
#288081 - 12/10/2006 12:54 Re: Manual disk build instructions ? [Re: Roger]
Arg, Roger, stop changing things around like that! I have to keep editing the drive upgrade guide and the FAQ each time you reformat your web site!
#288082 - 12/10/2006 12:57 Re: Manual disk build instructions ? [Re: tfabris]
Okay, edited the drive upgrade guide. But now I don't remember which FAQ entries had links to your web site.
#288083 - 12/10/2006 13:05 Re: Manual disk build instructions ? [Re: tfabris]
Sorry. I decided that when I moved the website to a VPS host (it's now hosted in Seattle, rather than at home in London), that I ought to rearrange the content. This makes it easier to run a multi-site installation of both drupal and gallery2. It also allows me to methodically fix up the broken attachments.
I had some magic mod_rewrite stuff going on that would have made it transparent, but I turned it off last week while debugging a problem with Gallery, and forgot to turn it back on.
My bad.
#288084 - 12/10/2006 22:19 Re: Manual disk build instructions ? [Re: Roger]
Thanks for writing the great guide it was very easy to follow and I had no problems with the drive replacement.
I wonder why I couldn't get the builder to work the 2.0 upgrader worked fine I am only using 20GB drives.
