Page 2 of 2 < 1 2
#289021 - 31/10/2006 09:42 Re: Hijack v464: Required for drives larger than 132GB [Re: Robotic]
then be able to sift from the Hijack menu
But that'd be lame because you'd have to remember to do it. How 'bout some way to run it automatically after any music is added when running anything less than a V3alpha?
Perhaps Hijack could keep track of the highest FID on a player and then on bootup run fidsift when the highest FID has changed?
#289022 - 31/10/2006 10:31 Re: Hijack v464: Required for drives larger than 132GB [Re: JBjorgen]
would you want it in the kernel? easily scripted, and could run from config.ini (I'll need to check this, but it seems reasonable) so that should be all you need.
#289023 - 31/10/2006 12:37 Re: Hijack v464: Required for drives larger than 132GB [Re: frog51]
True. It seems it would be possible to script it. I'm not going to venture it though. I use V3A11 so the motivation is somewhat low for me.
#289024 - 31/10/2006 14:12 Re: Hijack v464: Required for drives larger than 132GB [Re: mlord]
Once again, I don't have an empeg in front of me to check this with, but it ought to be something like:
kill -2 `set $(ps ax | grep [p]layer); echo $1` ; fidsift.sh ; /empeg/bin/player
You'll probably have to specify the path to fidsift.sh.
Page 2 of 2 < 1 2
