#300573 - 13/07/2007 13:53 Small/Embedded Ethernet Bridge
Ezekiel
Loc: NH USA
While doing some non-empeg work, I came across DPAC/Quatech embedded RJ45 to 802.11b bridges. Very small, with $129/ea pricing (list).
I don't have one, but thought the link might be of interest.
Best,
-Zeke
WWFSMD?
#300574 - 13/07/2007 15:03 Re: Small/Embedded Ethernet Bridge [Re: Ezekiel]
Imagine one of these wired directly inside the casing of an empeg. Assuming someone could write a configurator app for the empeg's main screen, you could have a wireless empeg from your car without installing a bridge behind your dash. Or bring your empeg anywhere with a 12v AC adaptor, and have it wirelessly connectable.
Hm. I really like this idea.
#300575 - 13/07/2007 15:37 Re: Small/Embedded Ethernet Bridge [Re: tfabris]
Ezekiel
Loc: NH USA
There'd still be the issue of mounting an antenna outside the faraday cage/steel empeg housing. The only 'harder' part would be supplying the 2.5V supply. It seems compact enough to mount to the rear or sides of the DIN cage, still requiring the RJ plug hack, but neater than a big old WET11.
If I end up moving forward with this part and get any, I'll post details.
-Zeke
WWFSMD?
#300576 - 13/07/2007 15:41 Re: Small/Embedded Ethernet Bridge [Re: Ezekiel]
Naw, mount it inside and then run the antenna out the keyhole in the back and tape the antenna to the back of the empeg.
#300577 - 14/07/2007 00:37 Re: Small/Embedded Ethernet Bridge [Re: tfabris]
FireFox31
Loc: East Coast, USA
Or could the case BE the antenna? Or could a small antenna wire be routed in the blank space behind the fascia?
FireFox31
