#317504 - 24/12/2008 03:17 Bootloader Version 9.
FieroSTi
I'm trying to install a PCATS memory board into a MKII player, thus I need to update the bootloader to version 9. Anybody got a copy of the .rom file I need? I have the install manual, just need the bootlaoder file. Thanks to all who can help.
#317677 - 01/01/2009 23:59 Re: Bootloader Version 9. [Re: FieroSTi]
FieroSTi
...anyone, haha?
#317769 - 05/01/2009 08:16 Re: Bootloader Version 9. [Re: FieroSTi]
FieroSTi
...does anybody know if I definitely need this?
#317776 - 05/01/2009 13:17 Re: Bootloader Version 9. [Re: FieroSTi]
I don't know that anyone ever even tried the 0e000 flash stuff on a Mk2 -- it was originally intended for Mk2a units, though the code may be common -- I'll check that here shortly.
Meanwhile, I did dig up this old post by me, referring to Hijack's built-in export for RAM expansion:
http://empegbbs.com./ubbthreads.php/ubb/showthreaded/Number/196470
EDIT: since the 0e000 files are installed by the s/w upgrade process, it appears that Mk2 and Mk2a units share the exact same file. Good. But you don't need to replace it for extra RAM.
Edited by mlord (05/01/2009 13:21)
#317779 - 05/01/2009 13:28 Re: Bootloader Version 9. [Re: mlord]
Here's a link to Hugo's original 0xe000 hack.
http://empegbbs.com./ubbthreads.php/ubb/showthreaded/Number/196379
But I'm pretty sure this is unnecessary now.
Edited by mlord (05/01/2009 13:29)
#317833 - 06/01/2009 17:29 Re: Bootloader Version 9. [Re: mlord]
FieroSTi
Awesome, Mark...so this means I don't need to mess with the bootloader?
#317851 - 06/01/2009 19:37 Re: Bootloader Version 9. [Re: FieroSTi]
That's the idea. You can still mess with it if you like (just one simple command to upgrade it), but there's really no need to.
#317858 - 07/01/2009 00:37 Re: Bootloader Version 9. [Re: mlord]
FieroSTi
Sounds good to me...doesn't seem worth the possible damage should the player lose power mid-upgrade. I'll just throw the board in and see what I get, haha.
#317865 - 07/01/2009 03:21 Re: Bootloader Version 9. [Re: FieroSTi]
The chunk of code you load into E000 isn't the protected bootloader. You can reflash it with the serial flash utility.
