#327251 - 01/11/2009 02:05 emplode does not find rio car using windows 7
edsmiata
Loc: New Jersey
so i got this new pc with windows 7...downloaded emplode...installed it and the little flashlight just keeps going back and forth when i try to find my rio car.
this worked fine under windows xp
any ideas what i did wrong
thanks,
EDIT: did some snooping around here and instead of using USB used ethernet and it found it just fine....my pc and player are like peas and carrots again!
Ed
Ed
Edited by edsmiata (01/11/2009 02:15)
#327252 - 01/11/2009 03:09 Re: emplode does not find rio car using windows 7 [Re: edsmiata]
JimCamel
No problems using emplode over USB on Windows 7 here.
#327255 - 01/11/2009 09:43 Re: emplode does not find rio car using windows 7 [Re: edsmiata]
The USB driver included with emplode 2.00 works fine on 32-bit Windows 7. It will not work with 64-bit Windows. If you're in this situation, use Ethernet. If you've got an empeg mk1, keep a 32-bit version of Windows handy.
Edit: as Shonky says, you can run x86 (32-bit) Windows on an x64 (64-bit) PC. You need to check your system properties to find out if your Windows is 32-bit or 64-bit.
If you've got less than 3GB of RAM, there's little point in running 64-bit Windows, but lots of people do.
#327261 - 01/11/2009 19:22 Re: emplode does not find rio car using windows 7 [Re: Roger]
edsmiata
Loc: New Jersey
its 64 bit processor...
also i just realized this new pc does not have a serial bus...is this the norm these days???
#327268 - 02/11/2009 02:15 Re: emplode does not find rio car using windows 7 [Re: edsmiata]
Yup, unfortunately. There are some things you can do if you need to connect to the empeg's serial port.
#327269 - 02/11/2009 02:38 Re: emplode does not find rio car using windows 7 [Re: edsmiata]
That doesn't matter (well doesn't conclusively prove if it's a 64 bit OS). What matters is if you are using a 64 bit operating system. You can quite easily run 32 bit Windows on a 64 bit CPU - and millions do.
#327305 - 03/11/2009 14:03 Re: emplode does not find rio car using windows 7 [Re: Shonky]
edsmiata
Loc: New Jersey
thanks for the feedback...it works fine with the ethernet cable....i will deal with the serial issue when it arises
ed
#327307 - 03/11/2009 14:39 Re: emplode does not find rio car using windows 7 [Re: edsmiata]
Good. Ethernet's faster anyway.
#350112 - 05/02/2012 14:54 Re: emplode does not find rio car using windows 7 [Re: Roger]
burdell1
have any of you tried running emplode on a mac with the Parallels software (running Windows 7?)
#358443 - 01/05/2013 16:20 Re: emplode does not find rio car using windows 7 [Re: burdell1]
hodge555
I use Window 7 - 64bit.
I sync over Ethernet using j-emplode (seems much more stable than emplode) and serial via USB to serial adaptor.
Both seem to work fine.
Hodge
#080000452
