#373625 - 02/12/2021 09:02 fascia designs
Mr_Maniacal
Loc: Salt Lake City, UT
Does anyone have files of fascia designs that I could use on a friends 3d printer or have them sent to be printed. If I find a UV light kit then I could get a 3d printed fascia and use a phosphorescent material or paint onto one, which would make some of the fascia glow. Anyway, does anyone have some pics? Thanks
#373628 - 02/12/2021 11:18 Re: fascia designs [Re: Mr_Maniacal]
I'd be amazed if Rob V didn't still have them. But also the intellectual property for those designs is almost certainly owned by Rio and now by whoever it was ended up owning Rio.
#373629 - 02/12/2021 14:30 Re: fascia designs [Re: Mr_Maniacal]
Tony and others have redesigned faccias, and Tony (tfabris) at least has/had his CAD files available for 3D printing by others. Hunt around here for that.
#373633 - 02/12/2021 16:51 Re: fascia designs [Re: Mr_Maniacal]
Mr_Maniacal
Thanks. I did end up searching for some fascia designs and found some that tony did for the display extender that he installed into his car.
#373636 - 02/12/2021 21:35 Re: fascia designs [Re: Mr_Maniacal]
The only problem with the ones that I did, is that they do not have the space for the handle. You'd have to modify the 3D CAD file if you wanted to make space for the handle.
Something to consider: If you want to replace the fascia with custom dayglo plastic, remember that the handle isn't part of that; the handle is cast metal.
#373639 - 03/12/2021 08:31 Re: fascia designs [Re: Mr_Maniacal]
Mr_Maniacal
HMMMMM. I see. I know you set up yours when you did it for the screen extender and you would not need a place for the handle. Thanks for the heads up. Still since I may use a display extender, since I have one, I may create one anyway.
