#374471 - 29/11/2024 03:08 Empeg again
CamGTS
Empeg Mark II
S/W - Not sure
Hijack V334
Emplode V2 (Windows 10 - 64bit)
My Empeg has been installed in a 1997 Nissan Skyline R33 for > 20 years, upgraded to a 30Gb disk at stage
Both car and Empeg rarely used in the last 10 years.
Hard Disk has died, won't spin up
My attempts to get a new hard disk working has been unsuccessful so far as I can't get connectivity to the unit which I thought would be the easy part of replacing the HDD but has caused me quite a number of late nights trying to reprocess all the old information on the internet and in my brain.
My first goal is to get connectivity with the unit:
Ethernet
- Unit set to AC and Home
- Blue LED at the back is on
- Switch detects port
- Emplode V2.0 installed onto Windows 10 64bit
- No response from unit in Emplode
- No DHCP request from Empeg on network
No idea what IP address is on the unit as all I can access is Hijack menu and 'No Hard Disk Found - Contact Support".
I do suspect that I had set a IP address as some stage as it would have made it easier to locate on the network but no idea what the range would have been. If at work would have been something other than 192.168.0.x
Is there any other way to determine what the IP address is so I can set my PC range accordingly? I'm guessing it's in the 10.x.x.x range
USB
I only have access to 2 x Windows 10 64bit laptops so I think this is out unless I want to mess around with a VM
Serial
Purchased a USB to RS232 Adapter - https://www.ebay.com.au/itm/315623365869? and now waiting on a DB9 female to DB9 female null modem cable to arrive as no idea where my original one is.
Cross fingers that this detects the unit then I plan to use the big bisk build to format a 60Gb disk.
#374472 - 29/11/2024 12:29 Re: Empeg again [Re: CamGTS]
The operating system is stored on the hard drive. So if it is not working, then most of the networking code will be unavailable. That's why that part isn't functioning.
So, serial port is the only easy option now.
#374485 - 12/12/2024 02:28 Re: Empeg again [Re: CamGTS]
CamGTS
Thanks mlord. Serial Cable turned up but unit doesn't show up in emplode. Not 100% sure where to go next.
Possible area's I can try are:
Replace serial cable (I can probably test this one to ensure the pins are correct)
Try a different PC
Buy a different USB to RS232 Cable
If no luck then I can get figure out how to get Win32 VM working and try USB.
assumptions I am making:
USB Port settings don't matter?
Emplode is working
#374486 - 12/12/2024 04:53 Re: Empeg again [Re: CamGTS]
Emplode won't work until you have installed a working drive, and run the "builder" stuff on it over serial.
#374487 - 14/12/2024 01:37 Re: Empeg again [Re: CamGTS]
CamGTS
OK so I need to follow these instruction for using the terminal
http://www.riocar.org/FAQ/7/82.html#82
I can use putty on Windows 10.
How do I know of success?
Do I get this response if there is no s/w on the unit?
empeg-car v0.04 19990121 ([email protected])
If there is anyone present who wants to upgrade the flash, let them speak now, or forever hold their peace...it seems not. Let fly the Penguins of Linux!
Once I confirm I can get a response from the unit I'll then figure out how to transfer the big disk builder to the unit and run it.
