#42083 - 17/10/2001 17:53 emptool-v2.00beta3 is busted
Under Linux (Mandrake-8.1), I run emptool-static from the v2b3 package, and then type "cd /".
It immediately segfaults to a horrible death, making it unuseable. Can anyone else out there try this and confirm (it won't harm your player).
My player is ethernet connected, for what it's worth.
Edited by mlord on 18/10/01 01:53 AM.
#42084 - 17/10/2001 17:55 Re: emptool-v2.00beta3 is busted [Re: mlord]
Downloading now...
Both the static and dynamic linked programs work fine under SuSE 7.2. I used ethernet as well. Although I did use emplode before using emptool with 2.0b3, that may have something to do with it.
Edited by Drakino on 18/10/01 01:58 AM.
#42085 - 17/10/2001 18:10 Re: emptool-v2.00beta3 is busted [Re: drakino]
No, emptool crashes for me always. This is after upgrading the player and using the windows beta emplode to check out some playlists and synchronize and whatnot. I even fixed the metadata stuff, and just plain nuked anything it complained about. Then back to Linux, and .. segfault city.
Edited by mlord on 18/10/01 02:12 AM.
#42086 - 17/10/2001 18:13 Re: emptool-v2.00beta3 is busted [Re: mlord]
mcomb
Loc: San Carlos, CA
Same for me on Redhat 7. It seems to work as long as you don't cd to the top level.
-Mike
#42087 - 17/10/2001 18:27 Re: emptool-v2.00beta3 is busted [Re: mcomb]
I just finished rebuilding it from sources, no difference.
It dies whenever doing "cd /" (or any path that takes one to the top level).
#42088 - 17/10/2001 18:35 Re: emptool-v2.00beta3 is busted [Re: mlord]
Works fine under RedHat 7.1 as well. Going to check to see if there is a 7.0 machine around in the lab.
[root@Linux001 empeg-car]# ./emptool.static
Scanning Ethernet for an empegcar...
empegcar 'DragonCar Music Player' (ID number 0) found at 207.94.12.96
Connection is 0x81055d8
2000 Checking connection [Done]
2121 Downloading
1260 Drive 0 size: 18976M, free: 162M, used: 18813M (99%)
1260 = Total size: 18976M, free: 162M, used: 18813M (99%)
2121 Starting download [Done]
2122 Retrieving tags index [Done]
2123 Retrieving databases [Done]
2124 Retrieving playlists [Done]
/> cd Techno
expand: added /Techno
2403 Current directory: "/Techno"
/Techno> cd /
2403 Current directory: "/"
I just tried it on a RedHat 7.0 machine, and would get this when exiting from time to time:
/> exit
Connection closed
pure virtual method called
Aborted (core dumped)
But working with it until the exit, it was fine. I'm not sure what the problem could be.
Edited by Drakino on 18/10/01 02:48 AM.
#42089 - 17/10/2001 19:44 Re: emptool-v2.00beta3 is busted [Re: mlord]
rjlov
Loc: Melbourne, Australia
If I specify the IP address on the command line (which I usually do), there's no problem. If I let it search for the empeg, then I get a segmentation fault on doing "cd /".
Richard.
#42090 - 17/10/2001 20:22 Re: emptool-v2.00beta3 is busted [Re: rjlov]
Yup.. specifying the ip address works for me also. Now I just have to incorporate something like that into my empsync scripts.
UPDATE: done.
My scripts now do "emptool -c" first, to obtain the IP-Address, and from then on they specify the IP-Address whenever invoking emptool. No more crashes.
Edited by mlord on 18/10/01 04:36 AM.
#42091 - 17/10/2001 20:56 emptool 'sync' locks the player [Re: mlord]
If my empeg (mk2) is playing a tune when I run "emptool" and then do a "sync" from within emptool, then when the player restarts (after the sync) the player continues playing the tune and IGNORES all button presses (local or on the IR remote). BUG.
#42092 - 17/10/2001 23:33 Re: emptool 'sync' locks the player [Re: mlord]
mcomb
Loc: San Carlos, CA
Yep, I get that one also.
-Mike
#42093 - 18/10/2001 04:17 Re: emptool-v2.00beta3 is busted [Re: mlord]
type "cd /"
FITNR.
#42094 - 18/10/2001 04:18 Re: emptool-v2.00beta3 is busted [Re: drakino]
> exit
Connection closed
Believed FITNR.
#42095 - 18/10/2001 08:41 Re: emptool-v2.00beta3 is busted [Re: peter]
Wire
Loc: Jylland, Denmark
FINTR, I wonder what that is ... better look it up on the net:
FITNR // adj.
Fixed In The Next Release. A written-only notation attached to bug reports. Often wishful thinking.
Apart from the last part, it sounds promising :)
Lars
Lars MkII 40gig 090000598
#42096 - 18/10/2001 12:14 Re: emptool-v2.00beta3 is busted [Re: Wire]
Dearing
Loc: Florida
OK, so, WITNR?
_~= Dearing =~_
_~= Dearing =~_
