#42120 - 17/10/2001 18:31 Transient Info on Tuner
Transient info mode on tuner doesn't act as I expected. When the info line is there and you switch presets, it dutifully tells you the name of the preset. However, when it "scrolls down" out of view, and you then switch presets, the line doesn't pop back up to show you the name of the next preset. I think it should pop up when you switch presets.
But visuals on tuner are way cool. :)
-Tony
MkII #554
#42121 - 17/10/2001 18:44 Re: Transient Info on Tuner [Re: tonyc]
This is on the existing bug list and is in the release notes.
If you switch from an AM preset to an FM preset, it'll pop up. So always switch from AM to FM presets.
#42122 - 17/10/2001 19:16 Re: Transient Info on Tuner [Re: tfabris]
Will do! tsk tsk.
I LOVE the fact that AM and FM have different vis settings.. Wonder if they'd think about changing that to separate vis for each preset... that'd be swell.
-Tony
MkII #554
#42123 - 17/10/2001 19:20 Re: Transient Info on Tuner [Re: tonyc]
I actually reported that as a bug. I thought that everything- am, fm, aux, player, should all share the same vis and info-screen preferences. I thought it would confuse people. Oh well, guess I was wrong.
#42124 - 17/10/2001 20:10 Re: Transient Info on Tuner [Re: tfabris]
BOO! Bad Tony. Thou shalt not report cool features as bugs!
-Tony
MkII #554
#42125 - 17/10/2001 22:21 Re: Transient Info on Tuner [Re: tfabris]
n6mod
Loc: Berkeley, CA
I'm with yn0t_ on this one. I'd like to have the AM stations just stick with Anna Vu. By the same token, I'd like to have the timecode setting be independent for the tuner and the player. I pretty much always want the clock showing in the tuner modes, but be able to switch the player timecode without affecting that.
As cool an idea as the guessed timecode is, there isn't enough dead air on commercial radio for it to find a "track" boundary.
-Zandr
Mk.I #0150 10GB
RioCar #010101243 10GB (96GB here I come...)
-Zandr
Mk.IIa #010101243 currently getting a 500GB SSD. More spares in the shed.
#42126 - 17/10/2001 23:11 Re: Transient Info on Tuner [Re: n6mod]
That's mainly useful on the Aux input.
#42127 - 17/10/2001 23:26 Re: Transient Info on Tuner [Re: tfabris]
n6mod
Loc: Berkeley, CA
All the more reason to have separate timecode settings for the tuner, right?
-Zandr
Mk.I #0150 10GB
-Zandr
