1) When I sync the first time, I get a lot of errors about invalid files when rebuilding the database. During this rebuild, the player reboots for every invalid file it seems. This is consistent, the same happens every time. I turn on logging, and the problem disappears, and everything is OK.
2) When booting the player, the serial port says
Vcb: 0x405ae000
E !! mp3_decoder.cpp 1052: Failed to seek to offset 2617671, error=0xc0044000
E !! mp3_decoder.cpp 1047: Failed to find valid sync after seeking to offset 2617671, error=0x0044000
3) When syncing, There is an error on "Writing player configuration", after this, I must restart emplode because it has the wrong cookie. Player config *is* changed (I tested by changing the player's name)
Synchronixze failed while writing player configuration. Connection timed out (error 0x8004003e) and the player reboots, I noticed... This also happens when synching over Serial cable.
Empeg Mark II 18GB, USB sync
I'll try ethernet later, and in the car to see if it actually plays music :-)
Marius
Edited by jane on 18/10/01 01:40 PM.
