#42298 - 18/10/2001 05:18 beta 2.0 problems
jane
Loc: Copenhagen SW, Denmark
1) When I sync the first time, I get a lot of errors about invalid files when rebuilding the database. During this rebuild, the player reboots for every invalid file it seems. This is consistent, the same happens every time. I turn on logging, and the problem disappears, and everything is OK.
2) When booting the player, the serial port says
Vcb: 0x405ae000
E !! mp3_decoder.cpp 1052: Failed to seek to offset 2617671, error=0xc0044000
E !! mp3_decoder.cpp 1047: Failed to find valid sync after seeking to offset 2617671, error=0x0044000
3) When syncing, There is an error on "Writing player configuration", after this, I must restart emplode because it has the wrong cookie. Player config *is* changed (I tested by changing the player's name)
Synchronixze failed while writing player configuration. Connection timed out (error 0x8004003e) and the player reboots, I noticed... This also happens when synching over Serial cable.
Empeg Mark II 18GB, USB sync
I'll try ethernet later, and in the car to see if it actually plays music :-)
Marius
Edited by jane on 18/10/01 01:40 PM.
#42299 - 18/10/2001 05:29 Re: beta 2.0 problems [Re: jane]
Vcb: 0x405ae000
I've seen this one too.
-Tony
MkII #554
#42300 - 18/10/2001 05:31 Re: beta 2.0 problems [Re: tonyc]
jane
It seems to say this every time now...
Marius (Escort Cab + Mark II)
#42301 - 18/10/2001 06:30 Re: beta 2.0 problems [Re: jane]
Same thing here.
MK II BLUE/RED 12GB #923 + RADIO
#42302 - 24/10/2001 13:37 Re: beta 2.0 problems [Re: Taym]
fox
same thing here to, after upgrade from 1.2 to 2.0b3
also with dev kernle, starting fsck by hand results in the same error message
#42303 - 27/10/2001 07:35 Re: beta 2.0 problems [Re: fox]
Bill Walker
Loc: NZ
I just upgraded to 2.0B3 and have exactly the same problem. It won't pick up an IP VIA DHCP either.
MK II, (Blue but should be Amber) SN: 118
MKIIa
#42304 - 04/11/2001 16:33 Re: beta 2.0 problems [Re: Bill Walker]
Amarth
Loc: Helsinki, Finland
I see these same errors (2) when booting my Empeg (just upgraded first time to Developer image beta2.03 and watching the serial bootup screen..
Any word on this?
Empeg Mk2 090000839 (BMW 330Ci E46 -02) http://guildhouse.net/BMW330Ci/
