#43379 - 23/10/2001 04:16 can hear radio on aux
buts
Loc: sydney australia
if i lissen to the radio then switch to aux and turn the volume up to 0db i can hear the radio
andrew butler
sn 08000176 6G amber
andrew butler
#43380 - 23/10/2001 08:52 Re: can hear radio on aux [Re: buts]
Is your AUX connected to anything? If not, it could just be pick-up from the proximity of the tracks on the pcb....
#43381 - 23/10/2001 15:08 Re: can hear radio on aux [Re: altman]
buts
no it is not conected will connect something over the next week and see if it makes a difrance
andrew butler
andrew butler
#43382 - 23/10/2001 22:18 Re: can hear radio on aux [Re: buts]
Question...
At what volume do you normally listen to the player at? For instance, if you really crank it and you're rocking out and the speakers are at about the maximum they can handle, what does the volume readout say on the empeg screen?
If, in that situation, it's low, for example it's lower than -10, then your problem is simply that you've got your amplifiers turned up too high. Turn the amps down to the proper levels and you most likely won't hear any sort of electronic interference, tuner or otherwise.
#43383 - 23/10/2001 23:56 Re: can hear radio on aux [Re: tfabris]
buts
WHEN THE PLAYER IS AT 0 DB YOU Can still have a conversation in the car
andrew butler
andrew butler
#43384 - 24/10/2001 03:16 Re: can hear radio on aux [Re: buts]
The issue is, if the aux in is not connected to anything it's prone to pick up noise - this is due to the floating ground design to prevent ground loops on the inputs.
#43385 - 24/10/2001 09:37 Re: can hear radio on aux [Re: buts]
Okay, then that's not what I was thinking then.
#43386 - 25/10/2001 00:38 Re: can hear radio on aux [Re: altman]
muzza
Hugo, If you put a resister across the inputs would this solve the crosstalk problem?
Murray
dust me selecta
#43387 - 25/10/2001 03:53 Re: can hear radio on aux [Re: muzza]
You'd probably have to tie ground and signal of the aux input to ground.
IMHO though, this is not a problem with the hardware. Any input not connected to anything is sort-of irrelevant, as you wouldn't generally be listening to it anyway.
#43388 - 25/10/2001 08:57 Re: can hear radio on aux [Re: altman]
edwin
Loc: Druten, The Netherlands
I'm looking into fixing the AUX-in leads somewhere on the sled, thus connecting ground and RCA shell together. This way it surely won't cause any 'problems' when not used. Now the leads just hang in free air and can possibly hit anything you just would not like them to do so...
Is connecting the shells of all 6 RCA plugs together a bad thing?
[white]­­______________[/white]
Edwin de Vaan aka FLaSHmAStER
#43389 - 25/10/2001 11:08 Re: can hear radio on aux [Re: edwin]
No, it should be fine.
#43390 - 25/10/2001 15:41 Re: can hear radio on aux [Re: altman]
jwickis
Loc: India
Like the old doctor gag, if it bothers you then don't listen to it, unless noise is favored by you.
