#57729 - 10/01/2002 20:26 rio 30
thrasher
Can anyone tell me if I can hook this up to my stock sterio in my 2002 chevy hd 4x4 with onstar. Im using two amps 1500bd and 1000 hp fosgate. will I be able to switch between the too so i can use my stock tuner Thanks for any help.
040103958 60g
#57730 - 11/01/2002 03:42 Re: rio 30 [Re: thrasher]
It depends whether or not your existing stereo has a line level AUX input (and whether or not your dash has space for a second standard-DIN-sized unit). If so, then you should be fine.
#57731 - 11/01/2002 16:57 Re: rio 30 [Re: peter]
thrasher
thanks for the reply. There is a cd changer and a aux switch on my stock unit which controls a cassette player below my head unit . Im removing the cassette player and putting my rio there.If I could get a tuner for my rio I would probably just remove my main head unit just use the rio. To bad there all sold out.
040103958 60g
#57732 - 12/01/2002 20:47 Re: rio 30 [Re: peter]
dr427
I have a similar situation. I want to put a Rio in my '97 Honda DIN pocket just below my Head Unit. Space is not a concern, but the only Line Out converter I can find is here: http://peripheralelectronics.com/periph_products/new_products.htm
And from reading about it I am not sure the Rio will work with the AUX/CD.
Thanks for any input. Lurking before buying!
dr427
#57733 - 14/01/2002 06:03 Re: rio 30 [Re: dr427]
I think that some (not all) head units will only let you switch to the AUX input if they detect the presence of the same manufacturer's CD changer. This "detection" involves icky proprietary protocol over the CD changer bus, which our car player isn't capable of faking-up.
You should check with your head unit's manufacturer, or with a knowledgeable professional installer.
#57734 - 14/01/2002 07:42 Re: rio 30 [Re: peter]
dr427
Thank you for your input!
David
