#57907 - 11/01/2002 10:08 Is It Possible?
justinlarsen
Loc: Petaluma, CA
would it be possible to port the winamp avs sytem. to use on the empeg?
---- Justin Larsen
#57908 - 11/01/2002 11:02 Re: Is It Possible? [Re: justinlarsen]
All you'd need to do is write (or port from somewhere) an x86 emulator, and then do the whole Wine-module-loader thing that DivX does.
That's a "no", basically. It's jolly hard work and you'd never get it to run at any decent framerate.
#57909 - 11/01/2002 13:31 Re: Is It Possible? [Re: peter]
flashman
Loc: U.S.
While the Winamp avs may be too much to port over.... It sure would be nice if the visual styles in the Empeg could be added and removed in an a-la-cart fashion.
To be able to download and sync user contributed custom visuals into the player from the forum would be awesome.
There are a ton of visuals already on the Empeg but I would love the ability to choose which ones I would have avaliable to cycle through so I did not have to cycle thru so many to get to the ones I want.
12Gb MKII 080000516 Blue 20Gb MKII 010101303 Green 20Gb MKII 090001020 Green 30Gb MKII 10101980 Blue
#57910 - 11/01/2002 13:47 Re: Is It Possible? [Re: flashman]
beaker
Loc: England
If you are running 2.0b7 you can set up favourite visuals. Here's an extract from the release notes:
It is now possible to have a list of favourite visuals which can be cycled
by pressing the 'Visual' button on a Rio remote. The list is channel
dependent and resides in the config.ini file of the player as shown below -
This list could be updated via emplode eventually. Pressing and holding the
'Visual' button will toggle between 'Favourites mode' and 'All visuals' if a
favourites list is available for that channel.
config.ini :
[VisualFavourites_DSP]
count=n
1=Visual Name
n=Visual Name
[VisualFavourites_AUX]
[VisualFavourites_FM]
[VisualFavourites_AM]
#57911 - 12/01/2002 06:00 Re: Is It Possible? [Re: beaker]
justinlarsen
Loc: Petaluma, CA
yup i already know the favoriote visual trick.. its a goodie
---- Justin Larsen
