#59408 - 15/01/2002 21:07
tuners going,going,forget it
Loc: India
WOW seems like the tuner(s) modules are reaching $300 at auction. It would appear maybe bidders think the player comes with it. Judging by the price of players alone, being similiar, somebody will be disappointed.
#59410 - 16/01/2002 04:01
Re: tuners going,going,forget it
[Re: f_devocht]
Are you sure you need to replace the amp there is a few Audi TTs on the board with BOSE sound systems and they jut get an adaptor and plug it in
Aberdeen Scotland
#59411 - 16/01/2002 06:30
[Re: thinfourth2]
Loc: Belgium
I'm pretty sure. The problem is that the Mercedes headunit has no pre-outs. So the Bose amp uses its speaker outputs as input. Since the empeg has no speaker outputs I have no way to connect it to the Bose. The 4V outputs of the empeg cannot be used as input for the Bose. Only thing I can do is replace the Bose (which means tearing the car apart to run new wires) or add a 2nd amp between empeg and Bose amp, which is rather silly (and would require new wires too).
I have the unit lying on my dining table for about 2 weeks now, looking for a solution
Frank
#59412 - 16/01/2002 07:04
[Re: f_devocht]
you can get speaker to pre amp level converters
#59414 - 16/01/2002 12:23
[Re: f_devocht]
Loc: FL, USA
How about getting a new car?
SCNR.
Georg
#59415 - 16/01/2002 16:45
[Re: f_devocht]
Loc: India
It would fetch a good price at auction or here for that matter.
#59416 - 16/01/2002 19:36
[Re: f_devocht]
DUH! sorry I don't know what I was thinking
#59417 - 16/01/2002 19:49
[Re: f_devocht]
Loc: Raleigh, NC
Hey f_devocht, check out this page and tell me if that's what you're looking for. In particular is the PDC-LOC which is a conventional line-out converter, but states that it's bi-directional.. Also states that it adapts OEM equipment to Mercedes Benz and Bose systems..
#59418 - 16/01/2002 22:50
[Re: Yang]
You *should* be able to get a small converter box like this, yes. You need an amp, correct, but it doesn't need to have power - just a decent voltage level output. The inputs on the bose amp will be high impedance, so little current will flow.
As mentioned, PAC do several boxes, as do Soundgate.
#59419 - 20/01/2002 12:31
[Re: altman]
Loc: California
I took two $5 amplified speaker sets, ripped out the amps, and put them in a project box. It cost me about $15 total and they sound good. The THD is 0.2%, which is not bad for a $5 speaker set. I had to add 10k pull-ups after the output coupling caps to keep my stock VW amp turned on. The only problem is ground loop noise. I used the RCA outs as the ground for the amps, and that helped. It seems there is current ripple on the DC input to the Empeg, hence the hard drive noise through the ground lead. Are there low-Z caps on the input to the switchers? I may modify my Empeg harness to add a lower impedance ground wire. Has anyone tried this? In reality a differential input for the amps would be best.
Speedy
#59420 - 20/01/2002 15:15
[Re: Yang]
Loc: Belgium
Wow, thanks for that link! I never realized (realised?) that these things existed. I'll contact them for more info.
Seems I'll be able to install the empeg afterall ... if it wasn't for that factory dual din nav unit that I'm thinking of installing too ...
Mmm, I can always strip the empeg and install its display in the ashtray.
#59421 - 20/01/2002 15:50
[Re: altman]
Loc: Belgium
I'll check out Soundgate too, thanks!
Frank
