#6087 - 21/09/1999 14:08 Volume Level
sysboy
Loc: United Kingdom
Is it possible to make the player program 'remember' the volume with respect to the power source. I tend to listen to the empeg through my home system with it set to 0db and in my car at a much lower level.
I've notice that you have a status file in proc showing the current power source, but I have not had the chance to see if it changes while in the car. If it changes then it should be a simple matter to save the 'in-car' volume and 'home' volume somewhere.
Steve
#6088 - 21/09/1999 14:31 Re: Volume Level [Re: sysboy]
Nils
Loc: Germany
I double that !
I was already close to blowing my car speakers 2 times when i remembered that it is still set at 0 dB !
Then i had to walk back to my flat, only to set the volume down.
But as i didn't know that there is an indicator for the empeg to know wheter it is powered in the car or at home, i did not post it in the "Bugs" section, but with my new knowledge, i would definately put it there.
And it is a DANGEROUS Bug too ...
Please fix that.
Nils
#6089 - 22/09/1999 04:42 Re: Volume Level [Re: Nils]
It's been on the to-do list for a while, it will get implemented :)
Can't promise it in the next release, but hopefully the one after.
#6090 - 22/09/1999 05:48 Re: Volume Level [Re: altman]
sysboy
Loc: United Kingdom
Thank you.
#6091 - 29/09/1999 08:55 Re: Volume Level [Re: altman]
dmoore
Loc: Houston, Tx, Usa
My AutoPC does a graduated volume increase on startup and after returning from mute. It allows just enough time to turn it down if needed.
David
Empeg 159
