#65324 - 31/01/2002 19:54 Slightly annoying Hijack v160 bug, or DEU..
ClownBurner
Loc: Irvine, CA USA
This is either a bug or it's a Dumb-End-User (DEU) problem...strange.. This worked in v151, broke intermittently (worked after a cold boot but not a warm one) in v153, and is broken now...
I have an ir_translation in my Empeg that looks like this:
[ir_translate]
Source=Source.L
I've also tried it like this, because I read about the strangeness in v156...
[ir_translate]
20DF03=20DF03.L
When I boot the Empeg, I get this:
ir_translate: Source=Source.L
It's just one of many ir_translations I have and all the others work fine:
ir_translate: Tuner=Sound.L,Three,Cancel.S
ir_translate: Search=Search.N,Search.N,Search
ir_translate: Popup0=Info,Shuffle,Repeat,Detail.L,Popup1
ir_translate: Popup1=Artist,Album,Genre,Popup0
Any clues? What am I doing wrong??
_____________ James Mancini
#65325 - 31/01/2002 22:53 Re: Slightly annoying Hijack v160 bug, or DEU.. [Re: ClownBurner]
Err.. more to the point, what was hijack doing wrong..
Thanks to your bug report, I've found/fixed the problem, and I'll put out a v162 shortly.
But the fix will undoubtedly break some of the more complex IR translations out there, so just a sec while grab the asbestos suit..
#65326 - 31/01/2002 23:46 Re: Slightly annoying Hijack v160 bug, or DEU.. [Re: mlord]
I take that back. It wasn't broken until v161.
But your coding can be fixed as well. Try this:
Source=Source.L,null
#65327 - 01/02/2002 09:17 Re: Slightly annoying Hijack v160 bug, or DEU.. [Re: mlord]
ClownBurner
Loc: Irvine, CA USA
using
didn't fix it on v161...but it works on v162...
Thanks!!
