#66590 - 04/02/2002 11:45 Whats to protect my RioCar while on a LAN at work?
Allistah
I came in today and hooked up my RioCar to my ethernet cable, external power, and my set of RCA cables at my desk. I then fired up emplode and saw another RioCar on the network. Wow.
Whats to keep that other user from connecting to my RioCar and deleting all my music? I connected to his and I could have done anything that I wanted. I dont think I like that. Any ideas on what I can do to protect it while its on a large lan?
-Allistah
#66591 - 04/02/2002 12:16 Re: Whats to protect my RioCar while on a LAN at work? [Re: Allistah]
There is currently no password protection built in to the car player. They have implemented password protection on the HSX-109, but there is no word on when that feature will get ported to the car player.
In the meantime, you can work around it two ways:
1) Use USB to connect the player to your work PC.
2) Put the player on a fixed IP address in a different subnet, as described here.
#66592 - 04/02/2002 12:18 Re: Whats to protect my RioCar while on a LAN at work? [Re: Allistah]
/me looks down
Good, wasn't mine, it's not plugged in today
(Rather parnoid of mine as well, since it sits on one of the larger private networks in the world.)
#66593 - 05/02/2002 13:51 Re: Whats to protect my RioCar while on a LAN at work? [Re: Allistah]
Hijack v182, place this into config.ini:
[hijack]
;@WORK disable_emplode=1
;@WORK kftpd_password=c00lDo0d35
;@WORK khttpd_files=0
Or instead of the last line above, maybe disable it completely:
;@WORK khttpd_port=0
#66594 - 05/02/2002 14:04 Re: Whats to protect my RioCar while on a LAN at work? [Re: mlord]
Allistah
NICE. Thanks alot! What determines if the player is at work or not?
#66595 - 05/02/2002 14:25 Re: Whats to protect my RioCar while on a LAN at work? [Re: Allistah]
loren
See this thread...
and try that handy dandy search feature of the BBS. Does wonders. =]
|| loren ||
#66596 - 05/02/2002 14:26 Re: Whats to protect my RioCar while on a LAN at work? [Re: Allistah]
If you have any ";@WORK" or ";@HOME" lines in config.ini, then there will be (v182) a Hijack menu entry for "Home/Work Location". Use that.
#66597 - 05/02/2002 14:27 Re: Whats to protect my RioCar while on a LAN at work? [Re: mlord]
loren
*sigh*
we really need a hijack faq. I guess i'd be willing to give it a shot... in my copius non-existant amount of free time...
|| loren ||
#66598 - 05/02/2002 14:42 Re: Whats to protect my RioCar while on a LAN at work? [Re: loren]
If you want access to add it to RioCar.org, I'll create an admin account for you...
#66599 - 05/02/2002 14:59 Re: Whats to protect my RioCar while on a LAN at work? [Re: drakino]
Allistah
Interesting. This is what I have in my config.ini file (at the very top) and I dont have the Home/Work menu option in the Hijack menu. Yes I do have 182 on it. :-)
Did I do something stupid?
[hijack]
kftpd_password=passhere
khttpd_files=1
voladj_low=0x3000,100,0x1000,25,60
voladj_medium=0x6000,409,0x1000,27,70
voladj_high=0x6000,3000,0xc00,30,80
#66600 - 05/02/2002 15:01 Re: Whats to protect my RioCar while on a LAN at work? [Re: Allistah]
crazymelki
Loc: Switzerland
it is calling Home/Work Location after High Temerature Warning....
bye
crazymelki.com
#66601 - 05/02/2002 15:12 Re: Whats to protect my RioCar while on a LAN at work? [Re: crazymelki]
Allistah
Hm, all I have is:
Force AC/DC Power Mode
Hard Disk Detection
High Temperature Warning
Knob Press Redefinition
<shrug>
#66602 - 05/02/2002 15:43 Re: Whats to protect my RioCar while on a LAN at work? [Re: Allistah]
beaker
Loc: England
Are you sure this is all there is? I take it you've tried scrolling up & down using the volume knob?
#66603 - 05/02/2002 15:46 Re: Whats to protect my RioCar while on a LAN at work? [Re: Allistah]
BUG!
I'll put out a v183 shortly.
#66604 - 05/02/2002 15:48 Re: Whats to protect my RioCar while on a LAN at work? [Re: beaker]
beaker
Loc: England
OK I take back what I said. Sorry!!
#66605 - 05/02/2002 16:30 Re: Whats to protect my RioCar while on a LAN at work? [Re: beaker]
Allistah
Sweet, v183 fixed it. Thanks Mark!!
#66606 - 05/02/2002 18:24 Re: Whats to protect my RioCar while on a LAN at work? [Re: Allistah]
Allistah
Mark, everything worked fine when the unit was in the office, but when I put it in my car, Hijack said there were errors with the config file. I switched it to @home and it did the same thing.
-Allistah
#66607 - 05/02/2002 20:31 Re: Whats to protect my RioCar while on a LAN at work? [Re: Allistah]
Connect to the serial port, and reboot. The errors will be noted somewhere near the bottom of the subsequent output.
#66608 - 05/02/2002 20:34 Re: Whats to protect my RioCar while on a LAN at work? [Re: mlord]
You can "simulate" DC/Car mode at the home/office, using the "Force Power Mode" option from the Hijack menu.. just don't forget to set it back to normal after you finish with it.
#66609 - 06/02/2002 10:20 Re: Whats to protect my RioCar while on a LAN at work? [Re: mlord]
Allistah
Sorry Mike, this was a problem on my part. I fixed it. I'll be sure to check the output of on the serial cable before wasting your time.
-Allistah
#66610 - 06/02/2002 10:58 Re: Whats to protect my RioCar while on a LAN at work? [Re: Allistah]
beaker
Loc: England
btw it's Mark.
#66611 - 06/02/2002 11:31 Re: Whats to protect my RioCar while on a LAN at work? [Re: beaker]
Allistah
haha, I know this. I guess I must have still been sleepin this morning. Sorry bout that Mark. :-P
