#66925 - 04/02/2002 21:12 access to the empeg over serial using a handspring
theory
Loc: Victoria, BC, Canada
Does anyone know how to connect a handspring visor to the empeg? Do I need a null modem cable, or can I just use the handspring serial cradle directly to the empeg?
-B
#66926 - 05/02/2002 16:10 Re: access to the empeg over serial using a handspring [Re: theory]
SQconstable
Loc: TX
I would also be interested in that. Would would be the application?
20GB Rio Car - sent by mistake? ...only ordered the 10GB!
#66927 - 05/02/2002 16:37 Re: access to the empeg over serial using a handspring [Re: SQconstable]
Nosferatu
Loc: France, Champagne
There is a prog Called PalmEmpeg.
Visor is Palm OS compliant so here is the link :
PalmEmpeg
Empeg IIa - 10 Gb - Red Fascia - Tuner, the day is coming - I Will Strike From the Grey -
#66928 - 05/02/2002 17:08 Re: access to the empeg over serial using a handspring [Re: Nosferatu]
TheAmigo
That looks like a cool tool!
I saw in another thread that there was some success with getting a Palm to speak TCP/IP to the empeg via IR. After getting a TCP/IP link, has anyone tried to use PalmVNC to connect to the VNC server on the empeg? IIRC, the Palm's IR speed can do 115200 bps, right? The empeg's 128 x 32 screen has 4096 pixels, but at 2 bits each fits a whole screen into 1024 bytes (uncompressed). That means that without compression, the 8192 bits could be updated 14 times per second! Drop it down to 10fps to allow for some VNC, TCP & IP protocol overheads and it'd still be decent. With compression, you could get a higher frame rate, but the Palm may not be able to keep up with that.
Thoughts? Is the Palm fast enough to display visuals from the empeg?
--The Amigo
#66929 - 05/02/2002 17:23 Re: access to the empeg over serial using a handspring [Re: Nosferatu]
SQconstable
Loc: TX
But how in the heck is that serial connection supposed to get the the handheld? With undea USB connection I can understand, but not serial cable...
#66930 - 05/02/2002 18:01 Re: access to the empeg over serial using a handspring [Re: TheAmigo]
VNC cannot deal with color depths of less than 8bpp. And since I'm currently not doing any real form of compression(), it sends the full screen every time. So 128*32*8bits=32768b=4096B per frame. And 115200bps/32768bpf=3.5fps. Oh, well. Maybe I can get the compression working soon.
#66931 - 05/02/2002 18:34 Re: access to the empeg over serial using a handspring [Re: wfaulk]
TheAmigo
Still, 3.5 should be plenty for seeing the menus and info.... visuals wouldn't be very useful.
So that might be an option for people without a place to put the empeg.... install it in the trunk and run an IR relay to the dash. Just point the Palm at the dash and you're set.
--The Amigo
#66932 - 14/02/2002 23:50 Re: access to the empeg over serial using a handsp [Re: wfaulk]
jimhogan
Loc: Seattle, WA, U.S.A.
Woohoo! Just got VNC running. That is sweet. I really appreciate your tackling this.
For now, I'm just running viewer from a PC over ethernet. Next stop, though, is VNC viewer from Zaurus, and then VNC from Zaurus over 802.11. Yes, I guess at some point compression couldn't hurt whether on serial or not, but I just wanted to say thanks for what you've done already.
Jim
