#68612 - 08/02/2002 12:31 Help, Just recieved my new unit, not working.
beamer
Hi, I just recieved my unit, but when i plug it in nothing hapens, besides from the blue stand-by led flashing. - i connected it to my PC, when i ran the update util, it ran fine until after the harddisc preperation. Then it wrote "Bad pump response to device select" error occured during stage 0x20 - harddisc does'nt spin up, please help.
update:
when i disconnect the harddrive it sometimes gets further in the bootprocess:
e000 v1.04
Copying kernel...
Calling linux kernel...
Linux version 2.2.14-rmk5-np17-empeg50 ([email protected]) (gcc version 2.95.3 20010315 (release)) #8 Fri Feb 8 18:48:15 GMT 2002
empeg-car player (hardware revision 9, serial number 30102818)
Command line: mem=16m
Linux NET4.0 for Linux 2.2
IP Protocols: ICMP, UDP, TCP
Starting kswapd v 1.5
Edited by beamer (08/02/2002 13:35)
- Regards from - Christian Byriel - Empeg MK2a
#68613 - 08/02/2002 13:13 Re: Help, Just recieved my new unit, not working. [Re: beamer]
Congrats on your new toy! Sorry it's not working, but it's probably no big deal. No need to panic.
Check this FAQ entry first, then contact support.
#68614 - 08/02/2002 14:01 Re: Help, Just recieved my new unit, not working. [Re: beamer]
beamer
Nevermind, unit working now, it was my powersource that was'nt big enough, just tested it with a car battery, worked, now i "only" have to find a suitable powersupply @ home..
#68615 - 08/02/2002 14:04 Re: Help, Just recieved my new unit, not working. [Re: beamer]
Okay, then, look here.
#68616 - 08/02/2002 14:11 Re: Help, Just recieved my new unit, not working. [Re: tfabris]
loren
uhhh... shouldn't one have come WITH the player??
|| loren ||
#68617 - 08/02/2002 14:13 Re: Help, Just recieved my new unit, not working. [Re: loren]
SE_Sport_Driver
Maybe bought a unit from the US store but doesn't live in the US?
#68618 - 08/02/2002 15:03 Re: Help, Just recieved my new unit, not working. [Re: beamer]
beamer
YEarh, i'm from Denmark, 240V - so i couldn't use the one that came with the unit.... i now use a PC powersupply, runs perfect
#68619 - 08/02/2002 15:09 Re: Help, Just recieved my new unit, not working. [Re: beamer]
loren
*smacks forehead*
|| loren ||
