#69856 - 11/02/2002 14:35 Inputs on rear of My Sony Head Unit
Will I be ok using the 4v lineouts from the Empeg into the CD changer input or do I have to use the 1v on the back of the unit ?
PS - I have a box to enable the aux in, so thats cool.
#69857 - 11/02/2002 14:38 Re: Inputs on rear of My Sony Head Unit [Re: Cris]
mandiola
Just use the 4v on the empeg docking cradle... not the ones on the back of the empeg (that would really be a pain). Don't you had how that stupid aux-in box is $99?
-Greg
#69858 - 11/02/2002 14:39 Re: Inputs on rear of My Sony Head Unit [Re: Cris]
This one is a FAQ Entry.
#69859 - 11/02/2002 14:55 Re: Inputs on rear of My Sony Head Unit [Re: tfabris]
Sorry, I had read the FAQ but I am unsure if I will damage the head unit or not by using the 4v output when I should be using 1v. I will just give it quick go and see what happens ???
BTW - Yes the XA-300 did cost a bit (almost as much as a changer in fact) about £93 inc postage etc.. I couldn't find it cheaper anywhere, not even Sony Parts in Heathrow knew about it so what chance did I stand. I could have used the cheaper AX-107 but Sony made the last one in 1995 and are like rocking house shite. Even considered using some info I found to enable the inputs with a PIC but it was to iffy, just put it down to experience. It is a lot cheaper for me to use my headunit and not buy all the amps etc....
#69860 - 12/02/2002 12:07 Re: Inputs on rear of My Sony Head Unit [Re: Cris]
Just gave it a dry run in the car using mains power and the 4v out put, works a treat, a bit loud though.
Sound quality is better than the cdplayer in the headunit I rekon.
Cris.
