#72331 - 16/02/2002 12:47 Long time for Synchro
AlB
Loc: SF
I have been loading my 30GB with lots of songs and lately it seems to be taking a lot of time at the "writing Player configuration" In Emplode (>5Min) This occurs regardless of whether I load songs or just plug it in and load Emplode. I am running latest beta 2.11 and win 2K pro.. Any Ideas??
#72332 - 16/02/2002 13:01 Re: Long time for Synchro [Re: AlB]
mtempsch
Could it be config.ini growing and growing with Favorite playlist entries? Which is a known bug.
Take a look at the config.ini file and check if you've got redundant visuals listings.
#72333 - 16/02/2002 13:14 Re: Long time for Synchro [Re: mtempsch]
Good guess. AIB, check this FAQ entry.
#72334 - 16/02/2002 13:37 Can't seem to even get emplode to run now... [Re: tfabris]
AlB
Loc: SF
Did the registry mod, emplode just hangs on the "retrieving player information" step now as you boot it up.....
#72335 - 16/02/2002 13:46 Rebooted computer, ran emplode, nothing works now. [Re: AlB]
AlB
Loc: SF
I can't even get emplode to run now, just hangs on Syncro "retrieving player info" step. Do I reinstall 2.11?
#72336 - 16/02/2002 13:55 Ok, after a ten minute sync... [Re: AlB]
AlB
Loc: SF
It was just what you guys said, I don't know about favorite visuals. Guess its time for FAQ review. trying to reboot and sync now....
#72337 - 16/02/2002 14:18 Still no go, but I know what the problem is... [Re: AlB]
AlB
Loc: SF
Grrrr... Ok I have a bazillion favorite visuals when I look at them through the Config editor that I added, I delete them using the emplode Tools: favorite visuals menu selection which takes a long time so I assume its doing this and re sync and they are all back. Do I delete them in the editor? the FAQ says use the Emplode menu to edit.
#72338 - 16/02/2002 14:21 Re: Still no go, but I know what the problem is... [Re: AlB]
AlB
Loc: SF
O yeah, and trying to edit the config file via the added shell will not accept keyboard input. Can I just delete the favorite visuals portion of the Config file??
#72339 - 16/02/2002 15:20 How do I start over....None of this FAQ seems [Re: AlB]
AlB
Loc: SF
to work. tried deleting config with shell, not sure what I did...can I just go back to 1.03
#72340 - 16/02/2002 16:49 Problem resolved....here was my method [Re: AlB]
AlB
Loc: SF
Please wait for Tony or someone to bless this before attempting!
I Deleted ALL the favorite visuals from both the tools:favorite visuals selection and then using the config editor here (2nd from bottom) modified the visuals section to look like:
[VisualFavourites_AM]
count=0
[VisualFavourites_AUX]
count=0
[VisualFavourites_DSP]
count=0
[VisualFavourites_FM]
count=0
It was rather obviious where the duplicates were. and I'm not sure if it was the fact that I deleted it in BOTH areas or maybe just all the monkeying I did (not a programmer here) with the shell prompt that did the trick. Whew... still learning here
